holley carb problems
Discussion in 'The Garage' started by TULSAK5, Apr 2, 2002.
  1. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    I have a new holley street avenger carb on my SBC now. On the road it runs like a raped ape but as soon as I try to climb with it it bogs, stutters, and will try to die. I heard that holley makes a part to fix this. Anybody have any input on this?
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I don't know alot about holleys, but a friend of mine was having this problem with his truck last week and he adjusted the float level and now it runs fine.
  3. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    They make an off road kit for it you can get through Jegs or Summit. That's why most guy's here don't run Holleys, the fuel starvation problem.
    Get a good Quadrajet from Jet or someone, problem solved.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    It's probally not a fuel starvation problem...
    It' probally flooding out the carb with too much gas when you get an any sort of angle.
    You can order up the holley off road kit.
    You can also just cut some 3/8" hose and extend the vent tubes.
    I'd try first just taking out the sight plug (on the passangers side of the 2 carb float bowls) and seeing how much fuel runs out...
    For the street a little fuel is supposed to slosh out when the fuel pump is on or when the engine is running.
    If you're gonna take it off road... adjust the fuel level 1/4" or a little more below the sight plug... bust out your straight screwdriver and 5/8" wrench and loosen the screw lightly and turn the 5/8" nut on the top of the float bowl clockwise to lower the float bowl fuel level. Seems like it's necessary to check this and maybe set it before going wheeling so you don't have these problems.
    /forums/images/icons/smile.gif
  5. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    yep Ryan is right! Your dumping too much fuel in. Lower the floats and it will be ok. I have a 650 double pumper on my Jeep that I did the same thing to.
  6. TULSAK5
    Feb 20, 2002
    93
    I appreciate the help. I'll have to try that this weekend.
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    No prob.
    You don't even have to wait till the weekend... it takes aobut 2 minutes to do.
    <blockquote><font class="small">In reply to:</font><hr>
    Beauty is in the eye of the beer holder.
    <hr></blockquote>
    Now that is a good sig!!! I like it!
    LMAO! /forums/images/icons/wink.gif /forums/images/icons/smile.gif
