Holley Contendor Manifold?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldbandit, Mar 19, 2001.
  1. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I'm currently rebuilding my 350 and i have a holley contendor manifold. Does anyone know the specs of this intake? If i remember correctly, it is a dual plane, but it has been awhile since i have seen it. It is currently in storage. What i was mainly wanting to know is, what is the rpm range of this manifold? I'm thinking it was the same as a perfomer, idle to 5500 rpm, but i'm not sure. I checked holley's website, but there was nothing about the contendor as they don't make this intake anymore. I looked for an e-mail, but didn't see one. Any info on this would be appreciated!
    thanks
    baldbandit
    "Have you outdriven a F**D lately?"
    Check out my site!
    <A target="_blank" HREF=http://www.baldbandit.coloradok5.com>http://www.baldbandit.coloradok5.com</A>
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    ive got a holley book from 89 have you got a strip contender or street contender?either way it seems theyre single plane it looks like the strip cont is and i quote"a true racing manifold".the street version is i guess streetable.i personally use perf rpm and like em still has good low rpm torque and throttle response but will sing to the top no prob.its just my preference.unless your buildin a hi rev bogger id go w/ a dual plane.itd be more friendly to lorpm tourqe.look in the big tires post someone asked about my motor(check signature)and i gave a pretty good run down of my combo.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.<P ID="edit"><FONT SIZE=-1>Edited by pureinsanity on 03/19/01 05:59 PM (server time).</FONT></P>
  3. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    I'm assuming that it is the streetable, because it has several holes that have to be plugged in the intake. Does it say what RPM range the streetable is?
    thanks
    Check out my site!
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    no it doesnt (that i can find anyway)but for the most part single planes are 3000 rpm up.they just dont respond well for torque.i can understand "use what you got"but if you dont have to,get a dual plane.youll prob lose low end with single plane.id almost use stock int over a single plane for off road.once again my opinion.anyone else got input???BTW strip contneder will have an air gap under the runners.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.<P ID="edit"><FONT SIZE=-1>Edited by pureinsanity on 03/19/01 07:10 PM (server time).</FONT></P>
  5. k5kraze
    k5kraze Registered Member
    Mar 17, 2000
    27
    AUSTRIA, A-7041 Wulkaprodersdorf
    I think the "Street Contender"-manifold is the predecessor of the "Street Dominator" (PN 30038).
    I´ve got a "Street Dominator" on my 350. It is a dual-plane with an rpm-range of idle-4800, just right for a K5.
    I guess Holley just changed the name, because 30038 was also the (old) PN of the "Street Contender".
    The intake works very well, I instantly felt an improvement over my old cast-iron stock one.
    "DO IT TODAY, TOMORROW IT MAY BE ILLEGAL!"
  6. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    i dug it out today. I will have to go look and see if the part # is on it!
    thanks again
    baldbandit
    Check out my site!
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    quote:"originally called"dominator"manifolds,holley changed them to"contender"in 1987".it would be best if i knew how to scan in the pages from my holley book and post it that way youd have what i do for info word for word and pics to compare to.ok i tried to scan it,my books too ragged out to be legible when scanned(sorry).keep askin quest. ill keep tryin to answer.
    PURE INSANITY
  8. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    Hey,
    Your right! I checked the part # and they match! THANKS ALOT! By the way, what cam are you running?
    baldbandit
    Check out my site!
  9. k5kraze
    Mar 17, 2000
    27
    Engine modifications are as follows:
    Weiand Cam (don´t remember the PN), specifications are 204/214 @ 0.050, .420/.442 lift
    Holley Street Dominator Dual Plane intake
    Holley 600 cfm 80457 carb (I don´t do any rockcrawling, mainly mud, so I junked the Quadrajet in favor of a few more hp)
    K&N open air filter (only used in the summer, in the winter I use the original air cleaner lid due to warm-up problems)
    1.5-inch Headers
    2.25-inch Dual Exhaust (no h-pipe) with Dynomax Super Turbos
    With this setup, 33-inch Cooper Radials and 3.73 gears and a TH350 I got 11-12 mpg.
    The engine worked well with my old 33-inch tires, but now I am in the process of building a 468 to get my new 38,5 Swamper SXs moving a little bit faster. I recently drove a friends 454-equipped 77 Burban and could not believe the difference.
    "DO IT TODAY, TOMORROW IT COULD BE ILLEGAL!"
  10. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    Thanks again,
    I found the cam holley suggests to use w/ their intake. Summit says it isn't available yet, and Jeg's says that it is discontinued. Although, Jeg's did cross it over to a Lunati cam part # 638-00018, but they didn't have the specs for it. I looked on-line and couldn't find anything on the cam at all.
    baldbandit
    Check out my site!
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    bald bandit,im glad you found what you needed.they must have changed the name again after my book was printed.according to mine its single plane.oops.any way good luck on your build and have fun.
    PURE INSANITY
