Holley Electric Choke Adjustment Question
Discussion in 'The Garage' started by rcamacho, Oct 26, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    My electric choke is not engaging at all. I've read the manual and will be going through the adjustment routing shortly. Dumb question though, after adjustment should the choke plate and fast idle cam be engaged when cold and no 12V, or does 12v have to be applied to engage? From the description it sounds like 12V controls heating of the element and dis-engagement so the choke should be fully engaged when cold.
    ???? /forums/images/graemlins/confused.gif
  2. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    I believe you are correct. The electricity is there to help heat the element.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    to engage the choke you have to slowly depress and release the throttle once
    this should be your normal cold start routine
    depress once to prime with fuel and set choke
    turn key to fire it up
    should fire up to fast idle and remain until you tap the throttle to release the fast idle cam
    multiple fast stabs on the throttle release the fast idle cam
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks!
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    did that get it for ya?
