Holley help?
Discussion in 'The Garage' started by dleroy43, Feb 10, 2006.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I got my 68 chey PU running today after the starter went out 3 or 4 years ago. The carb is a 600cfm holley. Besides the minior fuel leaks from dry gaskets, it pours fuel out of the secondary vent tube. It revs fine no vac leaks just fuel everywhere. I dont know crap about holleys but it was new with less than 2000 miles on it. why is it doing this?
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Bad fuel inlet valve or mis-adjusted. It could also be caused by particulate contamination of the needle. Try adjusting it or just replace and adjust.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Read this http://www.bob2000.com/carb.htm Lots of good solid Holley tech . Look near the top for common problems .
    This is one of the reasons I partially diassembled my carbs if they are gonna sit too long .
    I got to either sell or tear apart my Holley soon on the Chevelle ( I scored a Divorced Q-Jet for her ) :D
  4. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    Thanks for the link. I knew I needed to rebuild it anyways just wanted to find out why it leaks fuel.
