Holley or Edelbrock off-road carb
Discussion in 'The Garage' started by trailblazr81, May 30, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Has anyone used the "new" edelbrock or Holley off road carbs? Are they tat much better than a regular carb? I once tried to go wheeling with a regular Edelbrock an it would die or spudder at angles. Wasnt fun. I have a Barry Grant Speed Demon carb but its a street/strip carb and dont think it would help. I liked Q-Jets before but they dont bolt up to the Performer RPM air gap anifolds and I dont want to use an adapter.
    thanks
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    The only difference in the edelbrock offroad carbs is that they have the offroad needle and seats in them already as far as I can tell. The with the holey carbs the only thing that I know is different is they raised the venturi so that the bowles don't empty at large angles.
  3. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    well I know the Holley has "not-so-obvious features are a built-in fuel inlet filter and Viton transfer tube seals, clear site plugs for easier float adjustments, spring loaded needles and seats, an adjustable vacuum secondary, High Vacuum Signal (H.V.S.) annular boosters, electric choke, and metering blocks designed to "eliminate fuel spill-over through the boosters at extreme angles."
  4. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    So you have a brochure I take it.
  5. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    my buddy is using the Holley truck avenger, and it ROCKS!!!! It works better than my Q-jet! Never stalls, never sputers, idles GREAT, and he has a lot better TQ than he did with the 650 Holley he had before. (87 Sub. with a 383 and the TH700R4)
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I just bought a 670 truck avenger, and unless your motor is stock, it takes alot of tuning, so be prepared.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    yeah my truck avenger gets tedious too.... gotta re-adjust the choke on it.... finiky.. but I like it thus far... :grin:
  8. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Running the Holley Truck Avenger carb after trouble with the Q-jet on the really steep stuff and the Holley holds up to the ads.
    Does need tuning and choke adjustment and a little less fuel milage than the Q-jet but is well worth it, just got back for Hollister and was able to do all the things that left the Q-jet stumbling and flooding out.
  9. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    Trailblazr81, just noticed that you're from Hollister so you'll know where I went.
    My truck avenger got me up Truck Hill without a problem, did squeeze rock in my fullsize (what a site, got some body damage), ran the Gulch up and down and did the lower V's at the jungle. (little more body damage) Holley never complained. Loads up a little on really steep downhill and affects the power booster a little, more tuning :D
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Sounds Good!!! I guess I will go with the 770 Holley Truck Avenger. :cool1:
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Not meaning to hijack, but what can i do to make my 750 cfm edelbrock performer be more of an off road friendly carb? I've allready re jetted it, and was wondering of some other tricks that could make my blazer run his with out stalling? Thanks for the help.
  12. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Don't know what you got for a motor but a 770 will be overkill on most small blocks. Check with holley before you order or you can cause a loss of power, drivability and fuel economy. Bigger is not always better. My freind has a stock 454 and the 770 was too BIG for him.
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    agreed.... I called holley and they said a 770 is more for a WORKED 383 or WORKED BB not a stock sb or bb.... :crazy:
  14. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    i have a barry grant 625 cfm road demon and it seems to work pretty well on and off road i just need to tune it in more.
  15. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    I would really like to hear from someone who has used the Edelbrock AVS 1826 off-road carb.
    Anyone?
