holley pro-jection help
Discussion in 'The Garage' started by limey, Jan 19, 2004.
  1. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i just traded some work for a holley pro-jection system. i beleave it is the hole setup. the only problem is i cant find any instructions. i can only find instructions for the new units. this one only has Holley and fule controller on the computer. serial# I69a 09104. i dont think this one has halph the sensors if any one could scan the instructions i would apriciate it.
  2. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    Do a search for Pro Jection. You may have t go back a couple of years, but there is a reprint of the "instructions" here somewhere.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    next time take the time and make sure thats readable /forums/images/graemlins/rotfl.gif
    if u find some insructinos though id be interested in them to, becuase i may be comin into this setup myself.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    2 or 4bbl version? analog or digital? do you know which CFM option? I have the directions for the 900CFM 4bbl version.
  5. limey
    Dec 17, 2002
    121
    midland texal
    i just called holley and they told me it is the analog setup. it is a 2bbl. they told me the pink went to the starter terminal, the white is the -tach, yellow is fast idle, brown is temp sensor. red is ignition, all blacks are ground. and the red and green that are together go to the fule pump. but i have 2 relays and i forgot to ask if i hook up the fuel pump with the relays like the new setups.(now all i need it if the red and green from ecu go to activate the relay of straight to pump??)
  6. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    According to my instructions, The red and green go to the low voltage, apply side of the relay for fuel pump.
  7. limey
    Dec 17, 2002
    121
    midland texal
    cool that what i needed. thanks a lot, hopefully i can limp it to my shop tonight and tell yall how it dose tomorrow. thanks again /forums/images/graemlins/thumb.gif !!!
  8. limey
    Dec 17, 2002
    121
    midland texal
    ok it took 4ever but i finally got every thing put back together and the pro-jection on. but the fuel pump dosent work.. i rember their was a post a long long time ago discussing what after marked pump could be used.. but i could no go back enough in the search to find it.... it need to be an external pump that run at 15psi. any ideas what vehicle had a similar pump. or if anyone has a part # of a pump. thanks
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    put 12v directly to the fuel pump to make sure its
    the fuel pump, and not the wires/relay/ECU.
    All three are high failure items for the analog
    pro-jection.
  10. limey
    Dec 17, 2002
    121
    midland texal
    i checked the power at ther wires from the ecu and had 12+. and checked the relay and it is good. then i put the power strait to the pump and still got nuthing (wouldent hum vibrate or anything)
  11. Executioner
    Feb 22, 2000
    1,530
    What about ground(return power) ?
    Sounds like you may need a new pump. /forums/images/graemlins/frown.gif
