Holley Projection on a 305??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Oct 13, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I hope so because I just finished my install and when I took the truck to the shop to have some other adjustments made they said that the projection TBI system was pushing too much fuel for my engine. I know that the Projection has an adjustable fuel pressure so I could just turn that down right? The holley specs are for a chrysler, GM or ford V8. I assume that if I adjust the fuel pressure way down, I should be fine.
  2. dyeager535
    26,980
    Tough call. I'd expect if the TBI injectors on the Projection are enough to feed a 454 (what does holley say about that?) that would be too much for a 305. However, since people go with 454 injectors on 350's, a 350 injector (one that won't support the 454) might very well be fine on a 305.
  3. zach78k5
    May 14, 2000
    406
    It is for a max hp of 270, and the fuel output is adjustable. I will just have to install the air fuel ratio monitor in order to tune the system.
