holley projection ?
Discussion in 'The Garage' started by bryguy00b, Jan 16, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what does the harness plug into? is it really "plug and play" like they say..
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What model are you refering to? I have used two standalone systems.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    the 2 barrel 670 cfm one for mainly stock moters.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Does it have the stand alone controller with the small knobs to adjust stuff? I had that one and like it. Very easy to use.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yep, thats the one that I had. Its a real good unit. I wish I still had it in fact. I upgraded to a 900 cfm unit for the BB and sold it. I should have kept it and put in something else. They are not too bad to set up and made a huge difference in low end power. I think you'll like it.
    I mounted the fuel pump down on the frame. On the passenger side near the crossmember there was a spot on mine where the hard line goes to rubber for a foot or so. I spliced into that area for ease and I have not had to mess with it for years.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so it does not replace the pump on the side of the block? u just splice it into the line?
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It does replace the pump. The electric one goes back on the frame and then you have to run two high pressure lines. One from the pump to the inlet and the other from the outlet on the Injection unit to a return line. I also put my fuel filter before the pump to help keep it clean.
    I pulled all of the extra metal line out from the frame when I did this.
    Oh, the new lines run up the rear of the engine.
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh ok i see..can you use rubber line?
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I did. I just bought it from the local parts store. You have to buy the high pressure stuff for fuel injection though and it was expensive!
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok.thanx ill keep that in mind. /forums/images/graemlins/thumb.gif
