Holley Replacement TBI (Assistance needed)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Rhododendron, Mar 5, 2001.
  1. 88K5Rhododendron
    88K5Rhododendron Registered Member
    Sep 21, 2000
    25
    Outside of Rhododendron, OR
    I replaced the old TBI with a Holley replacement, because it is less expensive and is suppose to have better performance... Well it would seem it likes to use more gas, but the car overall is not performing very well. When I start it cold it runs so richly that you can smell the unburned gas in the exhaust, as well as the occasional backfire. When it warms up to normal the throttle is very sluggish and off the line it hesitates (I think this means it is too rich)... In any case I was wondering if there was some way for me to make it run more lean because the milage and performance is really starting to bug me (6 or 7 mpg)...
    Any help would be much appreciated!
    Matt
    gasoline4life! Or rocket fuel... I could see my blazer with some rockets on it... :)
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Did you replace the O2 sensor when you changed TBI? The O2 sensor is the nose of the system. It helps determine if it's running too rich or lean.
    Hope this helps
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Try timing the engine.
    I'll bet the timing was off to begin with -- to compensate for the worn out TBI unit.
    Now that you have a brand new one, I would assume the timing needs to be adjusted.
    Good luck,
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You might have to play around with fuel pressure
    Good luck
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It sounds as if the injectors on your new TBI have a higher flow rate than the stockers had. Since your computer doesn't know this, it is still using the parameters for the stock injectors, which would mean the engine will run rich.
    Was this supposed to be an exact replacement TBI or just a generic Holley ProJection TBI? If the latter, then it could be that you need a new PROM for your computer to compensate for the difference in fuel flow rate. [​IMG]
