holley spacer / adapter
Discussion in 'The Garage' started by RootBreaker, May 24, 2006.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    So tonight I took my carb off to install the .035 discharge nozzles... and VIOLA my hessitation on the truck avenger is gone.. that coupled with the black accelerator pump... anyways...
    when I did my cam, heads and intake... I still used the spacer to adapt the holley to a GM intake on my weiand power+ vortec intake.... so I took it off.. and of course Murphy was on my shoulder...... one of the stud bolts fell into my intake.. at least it was reachable... :doah:
    so anyway... I dont need the adapter as my intake has both sets of holes.... so I just simply used a holley stud kit.....
    theoretically what does the spacer give you? more torque or higher rpm hp??? I know you wont get alot of either but just curious... .I figured id just put a few fast stickers on my truck so that would be good for 45hp to even me out... :haha:
    (I am kidding about the stickers for you non understanders:crazy: )
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    There are adapters and spacers. An adapter is usually use to allow the use of a square bore carburetor on a stock spread bore intake manifold. Spacers are to (supposedly) increase the flow efinciency of a carburetor, but that is debatable.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    open spacer = more top end power
    split spacer = more bottom end power
    thay basicly make the motor think it has a bigger volume of intake storage area.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thats basically it.
    I run a 2in 4 hole spacer from Transdapt and I like it a lot. I got their swirl torque spacer, I don't know about the swirl part, but it seems to be working:dunno:.
    http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=12905&searchItemId=12147
    The adapter I used was this one that is about 1/16 thick
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=WND%2D9006&N=0&autoview=sku
    This is the adapter that Weiand recomends for getting a square bore carb to properly seal on a spead bore manifold. I have had no leaks at all since I installed them.
    I have a question too, if you run 2 or 3 open 2in carb spacers on a manifold, would that kinda make it a duel plane tunnel ram intake?
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    NICE yeah holley shipped the one on the bottome... zinc plated lookin thin piece.. i didnt use it..... if it is leaking what would I notice? lack of power? or would it be something not really even seen?
    I heard of doing a spray can.. wd40??? spray around and see if it sucks it in...
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    If your carb isn't seeled properly to the manifold, then it would cause a massive vacuum leak and I don't think your truck would run well at all.
  7. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    vacuum "leaks"...
    I see quite a few trucks and muscle cars with aftermarket manifolds that have a "universal" mounting flange for both spread bore and square bore carbs,and not using that flat plate is often the reason many of those vehicles had poor idle,stumbling on acceleration,and dieseling,due to vacuum leakage....they failed to see that even though the carb "bolts right on",that does NOT mean the base of whatever carb used will seal 100% all the way around..Holley and Edelbrock manifolds especially..
    I've had more than one guy bring me his truck to "rebuild the carb" and a "tune up" on a saturday afternoon,and all I'd end up doing was pulling the carb off,and I'd discover that the base gasket was not even touching a few spots on the intake!..I made a few of those "plates" before I found speed shops had them for sale!.
    More than one truck left here with only the new gaskets and spacer plate,running perfectly,and the owners retuned all the tune up parts and carb kit--and bought me a six pack or two instead!..:D :D
    I find at least one vaccum "leak" on just about every vehicle I open the hood on lately..or someone hooked the hoses up wrong!..:doah:
    And why do we call them "vacuum LEAKS",when in fact nothing IS leaking??....maybe we should call them a vaccum "SUCK" ..:thinking: ....:crazy:
