Holley street dominator manifold?
Discussion in 'The Garage' started by 70~K5, May 24, 2002.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I was looking in my garage resently and I found a unused SBC Holley street dominator does anyone here remeber what the specs on this maniflod were? Also it is setup for a front oil tube is that a problem to put it on a '70's sbc motor?
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I have one on my 2wd truck. I think they rate them for 0-7200 rpm. I bought mine from Jegs last year. I don't think they have the hole for the oil tube. But if the one you have is pretty old, the one I have may be a different design. My intake has the "street dominator" logo right in front of where the carb bolts on.
  3. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    I just gave one away. if it is a split entry (dual plane) then it will run 0-7500 RPM. If it is just a big hole for your gas $$$ to go then it runs 2500-7500 RPM. goes good but sucks the gas.
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I was looking at one the other day. It does not look nearly the quality of the Edelbrock.
    I don't see how a manifold can make power from idle to 7200, even though that is what they claim. Don't expect it to do that.
    I recommend the Edelbrock. Better quality casting and design
  5. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Yeah but I have this one here and it didn't cost me anything. All it would cost is the time and gaskets to install it. What I have on there now is the stock cast iron 4 barrel manifold. Would this be better than stock?
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Let us know how it works.
    John
  7. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    i have one on mimne it is fine. it or something else is uscking gas though. i only get 3-5 miles per gallon. If it gets in worse i am going to start measuring it in gallons per mile
  8. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Back in '76 the carb on my mustang bit the big one on a sunday and I had to get back to the Army base where I was stationed. A freind had a 3 barrel holley on his shelf that we thru on the car. A 3 barrel holley has a BIG oval barrel for the secondaries. It was like a 950 cfm carb too. You could see the gas gauge go down when you stepped on it. I got that sucker off the next weekend.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I personally do NOT like Edelbrock. I think you're paying more for the name then anything else. Quality isn't what it used to be with the Edelbrock. I much reather have a Dart intake manifold any day !!!!!! Wieand, and Holley arn't bad either.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd say give it a try, I use "Torque Plus" intake gaskets Jeg's part #886-1101 They cost alittle more, but I think they're worth it.
