Holley TBI unit problems?
Discussion in 'The Garage' started by jimmy88, May 9, 2002.
  1. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    I emailed Fastchip and they won't work with them, but didn't say why. Another post said they go out of adjustment? What, the pressure regulator? Are the injectors inconsistent? What else is there that could change. Anybody know whats up? Want to know what to watch out for on mine.
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    after talking wit Holley the number one problem is the engine running rich. A majority of the time it is beacuse the person who perchased the unit didn't get one with the right injector selection or they don't have enough motor to need the thing. You can adjust the fuel pressure to help lean or richen you fuel mixture with these. It works very well.
    IMO, unless you are going to a nasty 383 or 400, you can probably get by with a stock one or a bored out 454 unit and stock injectors.
  3. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    Unless you already own the Holley, <a target="_blank" href=http://www.TurboCity.com>www.TurboCity.com</a>'s TBI's are the way to go./forums/images/icons/smile.gif
  4. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    Have had the holley for a while now on a 350. Want to use it with the 400 small block. Just trying to find out what to watch out for while trying to make it all work together.
    Thanks for any info.
