Holley Tbi
Discussion in 'The Injection Section' started by Arakel, Feb 6, 2007.
  1. Arakel
    Arakel Registered Member
    Sep 25, 2005
    7
    Egypt
    My Tbi injectors gone bad so planning to replace my oem tbi with a Holley tbi unit any body has comments about the Holley tbi
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    if you are talking the 670 beffup unit. then its not a simple swap to do. lots of chip and tunning needed for best results and in stock bolt on it will give you some good problems from what i have read.
  3. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Yeah, I looked at that unit a while back, around the time I was looking for simple bolt on upgrades, and that didn`t fall into that category....
  4. Arakel
    Sep 25, 2005
    7
    Egypt
    tbi Holley crap
    Hi SweetK30
    They advertise the Holley tbi, 670 CFM Two-barrel TBI Model 3210 is a direct replacement for 1987-89 GM Pickup with a 5.7L V-8. Featuring a 2.00” throttle bore, which is a 42% increase over stock TBI and an air distribution ring. Provides increased torque and horsepower. Compatible only with stock GM electronics. For 366$ at sdpc2000.com
    Im located in Egypt and the tbi parts are available but expensive it wil cost to get 2 injectors and 2 sensors for the price above so i said what the hek get a new one, if you know more info about this tbi unit let me know, since the last i need is to change chips and all that electonic stuff
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    injectors are bigger / throttle bores are bigger / some have diffrent wire plugs / and needs lots of computer chip work to get the fuel / air maps correct to run. lots have tryed bolt on and 95% have failed. run rich and idels badly if at all. plus thay perform crapy . thay are good if you have the compur program and info to tune it best. but for your needs get a stock tbi unit.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    IIRC the TBI unit does not come with the injector pod or injectors. You must reuse your injector pod and injectors. You better read everything because i've read small print somewhere which said that. Also without modifying your intake manifold the 2" TBI will not allow you to open the throttle as the throttle blades will hit the stock bore on the manifold.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The Turbocity one? If that's so, that's a very misleading picture and description. Wonder how many people have been caught by that!
    My bad, just looked at it again and pic just shows bare housing. They're injectors aren't too cheap either.
  9. bladwin
    bladwin Registered Member Premium Member
    Oct 7, 2005
    71
    Seattle
  10. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would not go with the Holly unit. Too much trouble.
    Just get some stock injectors. Unless you have done a lot of performance mods to the engine you do not need a bigger throttle body. A nice set of flow matched injectors will improve your performance in a stock TBI
    Here's a couple of links from people I have delt with
    I dont know if he ships overseas but this guy has cheap TBI injectors:http://www.injectors4u.com/tbi_injectors.htm He does good work.
    Also fiveomotorsport http://www.fiveomotorsport.com/Injector_SetsGMTrucks.asp Is a very good source for injectors of any kind. They ship world wide.
