Holley throttle body injectors (UPDATE)
Discussion in 'The Garage' started by CyberSniper, Feb 6, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Holley #502-6 is a direct replacement 670CFM throttle body for engines that originally came with the smallblock throttle body.
    With my "elite" math skills you need 85 lb/hr injectors to keep up with that air. However, I'm afraid Holley put the little 65 lb/hr injectors in there thinking that it'd suffice.
    I believe the 65 lb/hr (#522-74) ones have a yellow top and the 85 lb/hr (#522-26) ones have a red top.
    Does someone know which injectors they put in this throttle body? Or does someone have one of these throttle bodies and can tell me what injectors came in it?
    EDIT:
    In case you guys didn't know, Holley's injectors look identical to Dodge injectors except for the 90 lb/hr injectors--those look like GM injectors.
    I stole some pictures off Holley's website. I don't know what color the 57 lb/hr (#522-14) injectors are because they don't have the correct image on their website.
    45 lb/hr (#522-72)
    50 lb/hr (#522-36)
    65 lb/hr (#522-74)
    85 lb/hr (#522-76)
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Re: Holley throttle body injectors
    I run an older Pro-Jection, it rated 670cfm also
    and the two injectors are Blake in color on the top.
    My guess is Holley used to but just enough to get by,
    now the new Digital injection, and throle bodies
    might actually make the grade.
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Good question...
    I just bought one of these used off of Ebay and should get it today. I had some concerns with the injectors too, and if they do need to be replace I will consider it.
    I really didnt want to replace my stock TBI, but after lookin at it hard and long, I didnt want to have to deal with it, and theused one I bought wasnt that old and looked to be in near new condition.
    Rob
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The Holley did (and does) not come with the 85's. The included injectors are 65's, or something close to that. Keep in mind however, that a Small Block PROM will not run the Big Block (85 lb/hr) injectors without reprogramming. The highest flow injector that I'm aware of, stock, that will run without reprogramming on a Small Block PROM are the Caprice 9C1 injectors, which flow somewhere in the neighborhood of 67 lb/hr.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, the difference between the bigblock and smallblock injectors are the impedance to my knowledge. The bigblock injectors are supposed to be rated for 80 or 90lb/hr at 90% duty cycle depending on if they were the early or late model.
    Anyway, Pro-Jection throttle bodies don't use GM injectors. They use the Mopar injectors.
    It doesn't really matter to me whether they're high impedance or low impedance injectors because I'm using it in a special application. I just need enough fuel to go with the 670CFM the #502-6 can flow.
    The GM style is on the left and the Mopar style is on the right:
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeah, that's what I'm worried about. I don't want to spend a lot of money on a throttle body and then have to buy injectors immediately. I figure the 85lb/hr injectors would support about 320hp.
