Holley Truck Avenger Carb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by biobry, Oct 27, 2004.
  1. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    Has anyone had any experience with these carbs on a K5? I am considering one on my 76 K5 but would like some feedback from those in the know.
    Bryan /forums/images/graemlins/k5.gif
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have a magizine article about it.
    I'll try to scan it and post it for ya. I remember
    it saying alot of good stuff about it. Once I'm
    ready for my bbc, I'll have one unless I get injection.
    It also tested the edelbrock, Q jet, and a typical holley.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i had one on my 73 that i sold to Muddytazz and i liked it alot!!!! im pretty shure he hasent run that motor yet but you might want to ask him
  4. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have one on my truck. I have had it for two years. I like it a lot. Next best thing to fuel injection, but the down side is that they take some time tuning to get it set up right.
  5. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    what he said.. /forums/images/graemlins/thumb.gif
  6. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    mine was almost set right out of the box. you might need a spread bore adapter though. paul (ryoken) still thinks i should have a little more power, so im going to get it looked at since im a newbie when it comes to carbs. it was an easy installation. i had to fab up a brand new throttle bracket adapter with a metal plate for the kick down cable to work right.
    so far i love it and that article was dead on!!!
  7. biobry
    Dec 26, 2003
    76
    North Florida
    Thanks for all the responses...I've been bouncing back and forth between this and the edelbrock...leaning towards the Holley.
  8. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    If you're torn between those 2 then for sufe go with the Holley. I have an Edelcrap on mine now. Hopefully the fuel injection setup will cure all my problem /forums/images/graemlins/peace.gif
  9. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    do you have the edelcrap off road carb or a 1406/1408 model carb?
    I know the 1406/1408 suck off camber, I was just wondering if the off road carb sucks or what results you had?
    fuel injection is the cure and in some cases the cause of insanity /forums/images/graemlins/rotfl.gif
  10. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I've run the Q-jet, Edelbrock 750cfm , and now I run the 670 Truck Avenger. The truck avenger is simply the best carb I've ever used. Absolutely no stalls, even when boucing up and down very steep grades. I had a TPI system to install and ended up selling it since the Avenger works so well. Always starts right up and has great power.
    It does take tuning though (like any carb). But the nice thing is that it is a very tuneable carb and very predictable. I swapped jets and pump cam per standard tuning procedure.
  11. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    sorry to hijack but I have a 670 truck avenger and I was wondering the proper way to hook up the electic choke on it. Does it need a constant hot or just and ingnition hot? Also, any tips on how to tune it, I have always just bolted on my carbs and just accepted how they work but I like this one so I think it might be worth tuning.
  12. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    Definitely ignition sourced power. The electric connection helps heat the coil for better operation. If it had power all the time you would probably burn it up.
    Preliminary stuff prior to tuning: set the timing, set the idle where you want it. To do the tuning have everything hooked up and the air cleaner installed. Get an assistant to put the tranny in drive and hold the brake while making the adjustments.
    I usually start with the mixture screws out about 2 turns. Then I adjust the screws with 1/8th turn increments in or out; it will depend on which yeilds the best results. I use a hand-held tach and keep adjusting to get the highest rpm. You could also do the same using a vacuum gage by adjusting to get the highest vacuum reading. I just like the accuracy of the hand-held tach.
    Hope that helps.
  13. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    Mrk5 - all good to know. This helps me with my carb situation as well b/c there was never a hand held tac, or vacume hooked up to mine and tyhe aircleaner was off the entire time - When you pay someone to "instal and tune" the carb - something along those lines should have been done, no? Thanks.
    BTW I'll get pics of my yellow beast this week for ya.
  14. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    I have the 1406 and have installed the off-road needle seats... before the off-road needles it would stall going up and down hill..after the needle seats I only stall going down... I'm looking into the TBI swap but have been told the Avenger is the next best thing.
