Holley Truck Avenger Carburetor????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gokartergo, Mar 23, 2002.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Any body tried the Holley Truck Avenger Carburetor... Or now of anybody that as... I am thinking about it.. Supposed to work up 40 degree up and down and 30 degree side to side...Dan
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Here is some info on it...<a target="_blank" href=http://www.samsoffroad.com/samsoffroadsto/HolleyCarburetors.htm>http://www.samsoffroad.com/samsoffroadsto/HolleyCarburetors.htm</a>
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    looks interesting. the power valve is still on it (i think) so that would still be a weakness. It sounds like a vacuum secondary which is good for milage, but is it a q-jet? visually obviously not, but why is there only one "size"? BTW, i don't have one and don't know anyone that does.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Basicly its a holley with all the mods 4x4ers have been doing to them for years(vent tubes, fuel bowl baffle, spring loaded float neelle) for off road use. The degree angles you quote sound about right for a holley modified for off road.
    As for the power valve Issue. New holley carbs have a little check valve in them that protects the power valve from backfires. So power valve problems arem't much of a problem anymore.
    But because of the type of float bowl set up holley has I still think that the Q-jet is a better carb for serious offroad.
    But for road and moderate 4X4 uses it would probabally be a good carb once set up right for your engine.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I am putting together a trail rig.. I am hoping the q-jet that was on it is OK..But if not I might go this way..But they don't even put down what the CFM'S are....Dan
  8. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    For the holley or q-jet. I am assuming the holley because the q-jet is 750 and 800 cfm...
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Heres all the info I have on it:
    P/N 0-90670 670 CFM Truck Avenger Carburetor
    BOWLING GREEN, KY - October 30, 2001
    Holley Performance Products the worlds foremost expert in fuel systems and carburetors introduces our new Truck AvengerTM Carburetor for the new Millennium and beyond.
    The Truck Avenger carburetor is unlike any other carburetor on the market, so simple it's virtually a bolt on deal. The new Truck Avenger carburetor was created out of a need for a simplistic design that would allow anyone with no past experience in carburetors to bolt it on, make two small tuning adjustments, and drive off. With only 670 CFM and a durable dichromate finish the Truck Avenger carburetor is the correct choice for any small block engine. Here are the features that will make this the last carburetor you will ever buy for your truck!
    1) A Quick change No TroubleTM vacuum secondary comes calibrated for optimum off road use.
    2) Fourth Generation No Trouble power valve with a lifetime blowout protection guarantee.
    3) Four vacuum ports consisting of PCV, spark, power brake and vacuum accessories such as A/C or modulator.
    4) A No Trouble electric choke with a factory calibrated setting that provides a cleaner smoother warm-up in all climates. The choke range has been identified and restricted so it won't ever loose calibration.
    5) The external No Trouble spring loaded needle and seats promote stable fuel levels for improved fuel control on rough terrain.
    6) New Truck Avenger CNC Machined annular boosters on the primary side provides maximum low end torque and power for improved towing and climbing.
    7) Exclusive No Trouble one-piece vent tube completely eliminates fuel spillover from during extreme maneuvers.
    8) Clear sight plugs ensure fuel level can be seen during adjustment and keeps you and your property safe.
    9) Square fuel bowls with single fuel inlet banjo fitting maintains precise fuel control and provides an easy "Bolt on and Go" installation.
    10) The New Truck Avenger fuel metering block eliminates fuel spillover through the boosters at extreme angles allowing for 45 degree climbing, 30 degree side hill maneuvers and nose-down descents to avoid hesitations, stalling and flooding typically associated with carbs in an off road environment.
    11) Step-by-step installation guide specifically designed for the Truck Avenger Carburetor.
    Want to know why this will be the last carb you will ever buy?
    Because Holley is so confident about our new Truck Avenger Carburetor that we gave it a Lifetime warranty on parts and a one (1) year warranty on labor with factory direct service.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    this is the only 'new' part that holds any interest.
    I dont think it qualifies as 'old tricks'
    I also dont believe there is any substance to these claims
    how can they prevent gravity from pulling fuel through the boosters
    they need to spell out what the metering block changes are
  11. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I agree with MJ.. what a bunch of bogus claims on those other "features"... their either the same things that are standard on other carbs, or stuff that has nothing to do with "offroading" .. what a joke. . I seen that carb on TV and they said it was $400 !^%$#! thats almost double the price of a normal holley.
    thanks Ill stick with my quadrajet
    mike
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Cheapest I have found it so far is $395.00..Not sure if it is worth it...Dan
  13. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    All I can say is. If you are putting together a trail rig. Dont buy the Holley. Get a Q-jet perferably from<a target="_blank" href=http://www.jetchip.com/fuel/streetmaster800.cfm>Jet Performance.</a>
    I have played with holleys all my life. They are a good street carb, And are passable off road with modifications. But I could never get one to do better off road than a Q-Jet. I'v used adapter plates and put Q-Jets on fords and jeeps with great results also.
