holley truck avenger ?'s
Discussion in 'The Garage' started by jp0863, Dec 1, 2005.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    looking to do a motor swap from a 6.2 oil burner to a small block or big block crate motor. i want to keep it simple so was leaning toward running a carb. a freind of mine has an edelbrock with the offroad jet kit which seems to work quite well, but i'm wondering if anyone is using a holley truck avenger and how you like it? my biggest concern is how well it will be on inclines and such. any feedback would be great, thanks.
  2. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    My buddy is using one on his Bronco. I have been really impressed with the angles it has run at. In fact, I have been so impressed it has been added to my "Need to buy" list. Or couse I am running an Edelbrock Performer so it probably would not take much to impress me. :D I have put in the offroad kit and adjusted the floats in mine, and it still cuts out on steep hills. My buddy did have to change jets, and work on his tuning for a while. Seems like it takes a while to get tuned in correctly.
    I guess I would go Truck Avenger, Qjet, and then Performer which would be way behind the first two. Talk with sledheadak on here for Qjet performance. He has one on his Jimmy and has had excellent performance with it.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The TA has been discussed a lot of times here. Do a search, I'm sure you'll find what you're looking for. As long as you get the -2 version and not the -1 you should be fine.
  4. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Exactly
    Refer to my posts in the following linked thread for more info on that:
    Click
    I'm satisfied with it on the trail. It's not fuel injection, but I think it works good.
