holley????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pjwalters, Aug 2, 2001.
  1. pjwalters
    pjwalters Registered Member
    Jul 30, 2001
    11
    kansas city ks.
    I just switched to a holley 600 carb on my 83. I was wondering if all the hype about them being worthless on the trail is true? If anyone out there could give me some pointers or tell me how they like their holley it would help me out.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The biggest problem with Holley's is the front/rear mounted fuel bowls - on any good incline, they tend to flood out. The first thing to do with a Holley is to put a piece of hose across the two bowl vents, and cut a small hole in the top of the arc.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. pjwalters
    Jul 30, 2001
    11
    kansas city ks.
    will this totally cure the flooding problem?
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    they also make an extension for hte jets, so when your at an angle the jets are still sucking gas. I had a holley and hated it. every little hill and it would bog out. tried the tube on the top and the jet extensions and it helped a little bit but i said funk it and bought a quadrajet and love it. on the street the holley was basa$$ though
    sun desert offroad http://community.webshots.com/user/scoobydann
  5. pjwalters
    Jul 30, 2001
    11
    kansas city ks.
    so ther is no guaranteed way to fix this?
  6. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    This is bad news for me guys :( I have a 750cfm holley 4150 series carb on my 454! Does anyone know how to sure the holley incline problem that Pugsley points out?
    If not, anyone need a Holley? ;) Will trade for anything that does not bog!
    Does anyone else smell BFGs burning???
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  7. ScoobyDann
    Mar 9, 2001
    305
    no guarantee in my personal experence, mabye you'll have luck mabye not, but the quadrajet is the closest CARB to fuel injection
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    There really is no way to cure the Holley's bogging problem - extended vents and angled jet plates will help some, but not really enough to make the Holley a solid performer in the dirt. Quadrajets rule the rocks, plain and simple.
    Generic Signature
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Bummer... once I have mine thru the dirt I will post again! I just got her on the raod last Thursday (its our 1 week anniversary!!![​IMG]) If it sucks, I will sell that thing faster then greased lightening!
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I can tune a holley with the best of them. but I could never get one to keep from flooding on a steep hill. I'v tried the slosh kits and mounted them every way but upside down and still had problems. Al though I could improve their off road capabillties. Having a carb that would flood out and stall just when I needed the power used to piss me off to no end.
    The Carter AFB type carbs also suffer with the same problems as the holley.
    From my experience the Q-jet is simply the best carb for off road. I even bought an adapter plate and put one on a Bronco with great results. I know other ford drivers that run them also. There are more than a few fords out there that should be sporting the " Built ford tough with Chevy stuff" bumper sticker.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have had no problems with my Edelbrock but I'm building a Q-jet for mine.
    Tim
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tim
  13. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    Two words: Quadrajet....wait (counting fingers...)
    Anyways, short of going to fuel injection, a Q-jet will be the best carb for inclines and all around off roading. The small primaries also help your gas mileage.
    Shutup Brain or I'll stab you with a Q-Tip - Homer J. Simpson
