Holley's Pro-jection
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric78K5, Oct 14, 2000.
  1. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    Holley\'s Pro-jection
    Hey guys! Has anyone tried this? Summit has the kit for $700, which doesn't sound too bad for a complete fuel injection setup. I'd like to hear from anyone who has this!
    Eric78K5
    K5-Because Size Matters!
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Re: Holley\'s Pro-jection
    I think that injection system is the same one I have been running for over three years. I have had no trouble with it at all. It takes a while to get the proper setup but once it's set your done.
    Steve Frisbie
    85 m1009
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    It's a good deal!Once you have it, get back with me and I'll go over some tips on installation that aren't in the manual that will make your life much easier.
  4. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Do not buy a projection unless it's a 4D or 4Di ($1400ish). Or better yet, swap on a GM system (TBI or TPI). Will cost between $700 and $1400! Many advantages to GM.
    I speak from experience.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  5. Grim-Reaper
    7,385
    Atlanta
    Yeah I have been eyeing that also. Few peopl I know have had trouble with the projection and like one of the other posts said Holly's instructions are screwed up. Something about the TPS. Here is another link to a company I have been eyeing. http://www8.bcity.com/fuel_injection/index.html From what I understand they basicly use off the Shelf GM parts for the main components with a modified computer to handle the fuel maps and transmission tyes ect. About the same proce as the projection. There is also a closed loop option that is not a bad idea and alows the FI to adjust for altitude and other things that the pre programmed versions won't
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I have been considering fuel injection since that day in august when i was so steep my motor wouldnt run. Is there any 4bbl FI setup I can get? Also, how waterproof are these systems? Right now, my whole truck is almost waterproof, and I dont want something thats sensitive to mud and water.</font color=blue>
