Hollister Hills RUN SEP. 22?
Discussion in 'Blazin Trails' started by DuneRunner, Sep 5, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    So who is interested in going on Saturday September 22nd. to Hollister? We will be meeting at 9am at the Ranger Station, thinking about staying the night, to have more fun Sunday.
    ALL are Welcome.
    KEN
    DANGIT it's not a bronco!
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I'm there...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  3. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    hmmm....
    <font color=purple>delta9blazer</font color=purple>
  4. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Come ON You know you wana[​IMG]
    Dan and I'll will lead again. LOL
    Hope you can make it.
    See ya, KEN
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    And I promise I won't take you into the brush that will scratch your blazer........HHHHHHHHHEEEEEEHHHHHHHHEEEEEE
  6. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I still haven't figured out the dually yet. If I get it figured out then I'm in.
    By the way. No codes, cat isn't plugged, O2 sensor working fine and temp sender working fine. Any clues?
    David
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Running to lean or timing is to far advanced...Dan
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    timing and rich and lean is controled by the computer so ya cant change it...
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
  9. Gold Rush
    1,498
    Well the base timing is at 4 deg. and that's just where it should be. The scanner is showing that it's going back and forth between rich and lean just like it's supposed to. Something must be intermittently causing it. Maybe an intermitent O2 sensor?
    David
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    But there is only a couple of things that would cause your exhaust to glow. Computer must be screwing up....Dan
  11. Gold Rush
    1,498
    Chaz,
    Yes you can change the base timing. You disconnect the computer lead to distributor and wahla you can set the timing.
    David
  12. Gold Rush
    1,498
    The computer could be wigging out, the O2 sensor or even a bad connection somewhere could be the problem.
    Pulling my hair out:
    David
  13. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    hhhhmmmm.....
    Maybe take off the manifolds and examine them for cracks,
    or get a new pair of headers...
    Thats my .02 Good luck Dave,
    KEN
  14. Chaz88K5
    2,979
    Stockton/Lodi CA
    Well as soon as you plug it back in it will set it to where its spose to be.
  15. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    So is any one else intrested?
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if the rig runs, i will be there
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  17. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Bro that was a message that I sent out about 3.5 months ago.
    I think that you ment for the Nov. 23-24 trip,
    As for me I will not make it there. I'm going to the Mountains. Up by Sonara.
    Later KEN
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
