holly # 12-802-1
Discussion in 'The Garage' started by rick357mag, Aug 18, 2006.
  1. rick357mag
    rick357mag Newbie
    Aug 18, 2006
    mpls
    Will the Holly in line fuel pump #12-802-1 work in a slightly wound up 1988 chev 350c1 throtle body injected engine?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If that is the holley blue pump then no it will not work as it has a max pressure of 14psi and you need more pressure than that. The TBI system uses between 13-15 PSI but the pump needs to put out around 20 PSI to work correctly.
  3. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    I thought the stock pump puts out about 7 to 9 psi. Holley sells a 13 psi inline pump that they recommend with the 670 cfm tbi which has injectors almost twice as big as stock.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    TBI uses between 13-15 psi
