holly 600 double pumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Oct 5, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Anyone use a holly 600cfm doublepumper??? It's gonna be on a edelbrock performer...
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run a holley 750 double pumper with mechanical secondaries on my Firebird. I love that carb. I have no problems with it. Holleys are so much easier to tune then edebrocks or carters. Just set the floats low if you climb hills so it doesn flood out and you will be fine.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    for why u put a holley ? in my experience they only give u bad gas mileage and need adjusted all the time . just .02cents
    i have a q jet works sweet .
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    STEPHENS OLD AXLES
    NO BREAKAGE :)
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I set my holley on my Firebird 2 1/2 years ago and havent had to mess with it at all. Holleys will actually give you better gas milage than an edebrock or carter carb because the new ones are set up for 400 plus hp. They run extremly rich and dont idle right. At my shop we have taken a ton of those carbs off because the car runs rough at idle and runs exremly rich, and put trhe holleys on had havent had a problem with one coming back yet.
  5. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Putting a Holley double pumper on an Edelbrock performer is like ice cream on potatoes. Edelbrock performers are a great street manifold and designed for low end torque and good fuel mileage. Holley double pumpers are meant to be used on a race engine and have no real place on the street. Yes, you can run them on the street but don't expect any real fuel mileage. Idle circuits are designed to be on the rich side, and they just can't produce the clean exhaust that many of Holley's other street carbs can. If double pumpers were so good on the street, OEM's would have used them during the muscle car wars of the 60 and 70's. They used Holley's in many cases but almost 100% were vacuum secondary operated. Makes more sense for the street. Holleys are poor choices for hard off road use but thats another story.
    A good firm grip is my idea of gun control!
  6. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    Have owned 2 Holleys in all the vehicles of my past. A 750 currently on a '53 F-350 w/460ci and have nothing but trouble with it. All the rest have been Q-Jets, and have had superb performance with them no matter what the application, and much better gas mileage than the holleys ever thought of having.
    www.saddletramps.com/BlazerK5.htm
  7. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I have two which I've run on the K5 (double pumper and Vacuum secondaries). Around town they are all right as long as you don't have any elevation changes which require re-tuning. Off road they tend to get sloppy on hills and don't do very well. Gas mileage is ok but not great. It's like any carb there, it has a lot to do with your right foot. The smaller primaries on the Q-Jet should deliver more off throttle response and a more turbulent mixture with less fuel resulting in better gas mileage. The biggest complaint with the Q-Jet is getting the transition into the secondaries to be smooth, but once you get it dialed in, it stays dialed in well.
    Verdict... I'll have a square bore vacuum sencondary holley for sale pretty soon. (sorry, the Double Pumper stays for the next street car)
    "I'm looking for a Dana60 Front Axle.." I asked, "You wish! HAHA" the wrecker replied!
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the accel pump on a quadra bog is a common sore spot.
    i still wonder what everyone says they 'adjust' on their holleys constantly??
    the only adjustment easily messed with is the idle mixture, and idle speed. once you get them set you never look at it again.
    off road troubles are all related to where the fuel is stored(float location) level doesnt have much(granted some) to do with it. as soon as the angle is high enough for the fuel in the bowl to be higher than the main discharge nozzle they gravity feed.
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I do a lot of elevation change out here in california going from one off road spot to another, sometimes over a 6,000 ft difference since I live at sea level. At 5,000 feet, I've got to change my mixture on the Holley as I start running rich. We all know what thats like with the back window open.
    "I'm looking for a Dana60 Front Axle.." I asked, "You wish! HAHA" the wrecker replied! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  10. michaelm
    Feb 2, 2001
    872
    so you rip out the main jets on the side of the road?
    you are dedicated
  11. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    No need to, just adjust the mixture on each primary, scew type
  12. michaelm
    Feb 2, 2001
    872
    the idle mixture screws, right?
    i just lived with it getting fat but the highway passes dont usually exceed 1200 metres
  13. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I run a 650 double pumper on my 350 LT1 crate motor in my camaro but the blazer I run a quadrapuke
