holly???sux???
Discussion in 'The Garage' started by chevy wrangler, Nov 3, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    well i havent been driving my truck 2 school lately, mainly due to the puddles of gas all over my intake manifold!!!!:mad: it leaks out of some where in the holly 650cfm, cant find out where and dont have cash for a rebult kit for about 2 weeks:eek1: any body have this happen to them ???:confused:
  2. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I fixed the same problem....its called an edelbrock.
    Ever since i put this new 1406 on my rig i haven't even thought about a carb. Before that i was screwing with the holley daily.
  3. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i bearly got it like a year and a half ago maybe even less!!! why?????????
  4. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    check your float bowls, Holly's like to leak from there and their metering blocks. I have dual holly's on my boat and they give me no problems at all. I set them up, jetted them once and have sense forgot they were even there.
    ~Brian
  5. grafixxman
    grafixxman Registered Member
    Dec 1, 2004
    70
    are you positive that there is nothing in the needle and seats? that would cause fuel to run up and out of the vent tubes, at least while it is running.
  6. bronderslev
    bronderslev Registered Member
    Mar 17, 2006
    21
    denmark
    yes but thae float device can still be stuck in the position so it will keep feeding gas in to the carb
  7. projectcop
    projectcop Registered Member
    Jul 13, 2005
    10
    northern california
    Holley's also leak from the throttle shafts where they go through the base plate. It comes from having too strong of a return spring on the throttle cable or linkage. disconnect the spring and grab the end of the shafts and see if they wiggle back and forth. If they wiggle more than a few thousandths of an inch, you are pretty much buggered. There is nothing you can do about it except getting a new base plate.
    Save your money and inject it.
    george
  8. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    it leaks when i turn it off and its all over the manifold from somewhere
  9. makovai
    Jun 6, 2006
    854
    oregon city
    it's prolly leaking all the time but the heat from the motor evaporates it when you drive it. Mine were constantly leaking on the throttle shaft.
    I bought all these an tryed everyone and finally gave up. My edelbrock has never given me a problem.
    BTW i still have 3 of them and they make nice paperweights.
  10. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    you need to see where the carb is leaking from first, shut it off and have someone check to see what is leaking? out the vent tubes, the throttle shaft, main bowls, check the float levels, etc etc. Holleys have been OEM parts for vehicles for decades and they work reliably if you know how to fix them/ adjust them.
  11. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    if it's a 4160 make sure you didn't pinch an O ring on the balance tube.
    Also if the lock screw on the float adjuster is loose it'll leak from there.
