Holly TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Jan 23, 2003.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I have to rebuild my TBI and looking at around $160. Is anybody running the Holly TBI on a stock engine and notice any gains?
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Don't waste your money unless you have done other engine upgrades.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I agree. Unless you've got a hopped up engine I'd forget it. Buy a power chip instead.
  4. pr1aw
    Sep 17, 2000
    144
    San Diego CA
  5. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    At 5000RPM at 85% effiency with 350c.i. motor you will only need 430cfm. At 6000 only 517cfm. 85% is pretty generous with a stock motor, not a seriously built motor is 95%, a all out race motor maybe 100%. So you have a 520cfm t.b.i., untill you increase the effiency you don't need any more. You will get more of a increase using a big block air filter setup with twin snorkels, and a K&N filter. OR you can cut out your base plate of your filter and rivet in a new aftermarket high flow unit that will not have that restrictive ring around your injectors. Always glad to help, had to make my own solutions when I did it.
  6. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Ahhh, good timing for this one!!!
    I was thinking about the turbo-city tbi but maybe my motor still doesn't warrant it. Free-flow dual, headers, K$N, stage2 chip, spacer.
    Think I'll just go with an adjustable fuel-pressure regulator instead. Anyone modified their own like it says at third-gen??
    smack
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You dont really need a bigger TB. The stock ones will build up to 300+ Hp np problem.
    I have modified my stock 1 11/16" bore TBI with the following from: turbocity.com
    Air flow Enhancer- Gave me more power
    TBI 1/2" Spacer- Helped with throttle response and low end
    Injector Spacer- More air flow
    Adjustable fuel press regulator- This is handy to be able to adjust the pressure to get the best sprey pattern it was one of the last mods I did to the TB and it helped to really fine tune it. With the stock regulator it seemed to starve out at higher rpm. The adjustable one cured it. Definatly gave more power.
    You can modify your own as per 3rd gen but the turbocity regulator has a big screw that hangs down you can turn with your fingers and is a lot easier to adjust
    Flow matched stock 55 lb hr injectors- If you need injectors, these are the only way to go
    I modified the MAP sensor with the fuel mixture selector.-Helps for better fuel economy.
    DUI ignition- In my opinion it is better than MSD and you dont need a box.
    Also have headers, flowmaster 3" single pipe, K&N and modified cold air intake.
    My K5 runs Very well for a stock 350 Everyone who has driven my truck has been impressd. Or so they tell me.
  8. smack
    Feb 24, 2000
    277
    Colorado
    Thunder, so you did get the bigger bore $220 tbi from turbo-city?
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    No. Still using the stock one. If I ever decide to put in a better cam intake manifold and heads I may get a reworked one. But for now my engine runs too good to tear into it. I'm a firm believer in Murphy's Laws so i'll leave like it is till it needs a valve job.
