Holy crap! Been running stock rod bearings on a .010 underground crank!
Discussion in 'The Garage' started by y5mgisi, Aug 22, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    First off let me say that i have put an esay thousand miles on the truck with it like this /forums/images/graemlins/shocked.gif. But i was strting to get worried when my oil pressure would drop to about 5PSI when warm. Plus i had s knock above 3000 rpm. So i pulled the oil pan and every single rod was loose on its journal. I could grab the flex plate and rotate it 3/4 of an inch either way before it would take up the slack i had between the bearings and the crank!! /forums/images/graemlins/eek.gif So i pulled one of the caps and mic'ed the rod journal and found it to be .010 smaller than stock. /forums/images/graemlins/yikes.gif So i put in a set of RIGHT bearings and wouldent ya know it.. I had good oil pressure and no more knock /forums/images/graemlins/thumb.gif My step dad is amechanic and he couldent belive that it even lasted a day like that. /forums/images/graemlins/doah.gif Not even one spun bearing /forums/images/graemlins/screwy.gif
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you got lucky!! But glad you found it in time!
  3. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Thats Chevy engines for you. You would be surprised how much a Chevy engine can take before it blows up. I took an old 67 Chevy Biscayne with a 327, and drained the oil out of it, then put a brick on the accelarator. It ran for 45 minutes that way before it let go.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I wish I was there that day . I would of stopped you . Because my project is sitting in my garage with NO engine to hook up to the 465 /forums/images/graemlins/frown.gif
  5. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    That was 25 years ago when small journal 327's where a dime a dozen. I bought the car as a piece of junk for $50. That engine had over 200,000 miles on it.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I had lots of cars then , maybe a good 30 or 40 ...............1/64th scale , I was 5 /forums/images/graemlins/histerical.gif
  7. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    25 years ago? /forums/images/graemlins/thinking.gif
    well my mom was pregnant with me /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    not to call you old or anything
    glad you found that in time amazed that you didnt do any damage...
  8. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Youngsters....... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  9. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    DAMN!!and I was impressed with an old honda that ran for 26 minutes WFO with no oil or water!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  10. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I had a Subaru Loyale in high school that I drove for a year with only 1qt of oil and the radiator only half full. I also had to stand on the brake pedal to get it to stop. Even then I had to trow in a prayer for good measure. The driver seat was broken and layed back so I had to use a pillow behind my back to drive. Also had to double clutch to upshift but could downshift normally. It was a total piece of junk but the power windows and locks worked as did the radio so I was set.
