Holy Pipe Fittings Batman!!!!!
Discussion in 'The Garage' started by BlaKK54Speed, Jan 21, 2007.
  1. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    ok, i took all the EGR stuff off of my 305. there is a pipe that screws into each manifold, i broke one off so it is stuck in there and i lost the pipe out of the one that did come out. now i have a hole in my exhaust and its really loud. What the hell size is this thing!!!!! i think its like a 3/4 compression fitting but i dont know. i think a 7/8 fine thread bolt would work too but the biggest that anyone has is a 3/4. this is really making me mad i have been looking for a plug for days!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. goldwing2000
    goldwing2000 Guest
    Throw some steel over it and weld it shut!
  3. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i never thought of that. thats good. i wonder if i could get in there close enough to weld it good
  4. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    im seriously thinking about just buying some headers and taking it to a muffler shop and running all new straight to the back!!!
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    That's not EGR stuff, that's AIR stuff.
    Geez, I thought it was 1/4" or 3/8". When I pulled my lines off, I used a threaded plug in each hole(I can't remember which size). If you're having a problem threading the old one out, heat it up with a torch first.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the individual pipes are 1/4", but the manifolds with a single pipe i believe are 3/4" pipe plugs.
  7. Can Can
    15,552
    136
    Hmmm. So GM had two different AIR line configurations?
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yes, one with 8 individual pipes, one to each exhaust port. or, one with a centrally located fitting in each manifold for a total of two.
  9. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i tried a 3/4 fine thread and it just slides into the hole. im really lost here
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    3/4 fine thread pipe fittings? i've never heard of such a thing. :confused:
  11. goldwing2000
    goldwing2000 Guest
    3/4 bolt thread and 3/4 pipe thread are two completely different things. Think ID (pipe) vs. OD (bolt). House stuff (pipe) vs. truck stuff (bolt)
    You can go to the hardware store to get some 3/4 inch black pipe but I still say to just weld it.
  12. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i tried a 3/4 bolt. they only make 3/4 and 1/2 pipe plugs and they dont fit. so i went to bolts.
  13. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    all pipe fittings are coarse thread, i need fine thread
  14. Can Can
    15,552
    136
    Cool, I learned something new today!!!:thumb:
    I've never seen the "one pipe" setup. I wonder why GM went with 2 different systems, instead of just choosing one and using it for everything?
  15. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I got a pic of it hold on a minute
    Ira
  16. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    i prefer the 2 fitting system, cleaner...
  17. sandawgk5
    Oct 28, 2003
    6,881
    Here ya go
    From what I can tell this style was on TBI trucks with the Non-serp accesories. It seems like the carburated and serpentine systems had the 8 port style.
    Ira
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've never seen a non-serp belt setup on a tbi truck. :confused:
  19. goldwing2000
    goldwing2000 Guest
    Probably not pipe thread, then. Is the thread tapered? \ /
    If it's not, then it's not pipe thread. Probably some crazy flare-fitting thread that GM dreamed up so people wouldn't disable their A.I.R. systems. :D
  20. goldwing2000
    goldwing2000 Guest
    I just saw two of them last week. Both 1987 K20s with TBI, both had v-belts on PS and AC and multi-groove on Alt and smog.
    I was told they didn't switch to full serp until later in the year and I've since heard about trucks into the 90s that had the same setup. :dunno:
