Holy price difference batman!!
Discussion in 'The Garage' started by 78Suburban, Aug 23, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I went by Napa today and ordered some brake calipers, and traded my front calipers in as cores. I still gotta run by and pick up some cores for the rear from a ck5er, but didn't get a chance today like I was hoping. The two rebuilt calipers and cheap set of brake pads ran be about 60 bucks at Napa. I asked them how much a set of rotors would be, and they said 100 bucks. I only had 70 bucks left in my pocket.. Drove right down the road to Advanced auto.... a set of rotors cost me only 63 bucks there.
    They are Wearever brand.. part number YH141049. I guess they're the same for both sides? Wonder why they were so much cheaper at Advanced? Also asked them on calper price at Advanced.. they said 16 bucks.. I paid 20 at Napa.. Maybe I should get my other set of caipers from Advanced....
    I still can't get over how much cheaper advanced was on brake rotors.. saved me 40 bucks!!! :eek1:
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,023
    849
    Pinckney, MI
    napa has the "Good stuff" lol
  3. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    have you ever seen a napa manufacturing plant anywhere. they sell the same thing that every other parts house sells but they pay the manufacturer to put it in there box.
  4. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Advance has two lines of the rotors, wearever and (i forget the other one). Made by Raybestos IIRC.
    The "other one" is made of a higer quality metal than the wearever.
    Both are the same thickness though and meet or exceed the OE requirements.
  5. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ya napa is def more expensive, although ive had better luck with there parts...going to discount 3 times to get a master cylinder for my buddy and 3xs i got the wrong one....:mad: on the other hand discount is cheaper $50 for a starter as compared to $100:eek1: at napa.
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I tell you what I go to car quest for one reason cause I know a guy that works there and he hooks me up. I do go to the cheaper stores to buy some stuff though. Probably always will. I have had both good and bad luck with all auto parts stores parts.
  7. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    I actually have decent luck at autozone, believe it or not.
  8. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    I normally will use NAPA or Carquest because they are locally owned where I live and I know I will get better service. So to me it is worth paying a little more to support a local business. As for Autozone, I gave up on them when I had a clerk actually yell at me because I disagreed with what his all knowing computer told him.
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have a account with Napa so my prices are not to bad.
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    So have I, but you have to know exactly what you are looking for.
  11. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    An account at napa gets me 10% off. A actual good counter guy/friend that has never given me a part that doesnt work,and thru the years I have given him some doosies!:bow:
  12. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I go to the NAPA here because there are 2-3 counter guys that know their ****, and one that actually knew the p/n for the conversion u-joint I needed off the top of his head. All the other parts stores in town I can't get a lug nut without telling them whether my cluster**** of parts in the garage had a/c originally.
  13. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    $100 for a set of rotors??????? Holy crap man, I only paid $28 each for my rotors.
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    My Napa blows Kragen and Autozone out of the water on pricing. It's in the account setup, even if you have an account, there are still different levels of price reduction. I get around 20% off what a normal customer would pay.
    Napa is the best because I can get rotors for my Dodge or Chevy, pick up a new hydraulic hose for my disc, and all the filters to change on any of my tractors or combines.
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The cheep rotors come from the China. I've run across stories of pre-mature warpage type problems. No idea where the Napa parts come from. Locally I'm able to buy direct from the brake parts w/d.
  16. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i stopped putting any faith in kragen when the guy at the register made a comment about me doing some exhaust welding when I placed a couple pieces of flex pipe, some regular exhaust pipe, and a bunch of clamps on the counter. I said no i was doing some exhaust clamping (hence all the clamps, duh). he then said that i shouldn't be using flex pipe because it limits flow. (i dont really care, my exhaust flows fine and flex pipe is great for me and my ever changing exhaust setup). So then he asked what this was for and i said an 82 K5, and he said, "What's that, like a Jeep or something?"
  17. diesel4me
    Jul 24, 2003
    17,559
    939
    Massachussetts
    If you want cheap--you have to SAY so!...
    ALL parts stores,whether it be NAPA,Autozone,or whoever,all have a few different brands and price ranges of parts!...when a customer walks in and asks for,lets say wheel bearings,they assume you'll want quality name brand ones like Timken,and thats just what they will sell you,unless you complain about the prices!..THEN they will say "OHH"--you want the CHEEP ones?...its the first rule of retail--sell the expensive stuff first if at all possible!..:doah:
    This happens to me all the time--but having been a parts counterman for 20+ years,I know all the sales pitches,and "tricks" of the trade--like putting CHINA brake rotors in Raybestos boxes,or swapping one brand of stuff for another,and using the "other" brands packaging..or just getting raped because its an unsuspecting female customer that doesn't know the difference between "list" price and "dealer"..
    I paid 28 bucks each for brake rotors for my 82 GMC Cabalaro I had,at a store 15 miles away from the one I worked at,because even with my employee discount,the cheapest ones we had were 56 bucks apeice!..we didn't stock that part # in the "cheep" line of rotors,so I bought them elsewhere (much to my bosses chagrin,but he only paid me 8 bucks an hour,so screw him!:p: )..
    Same deal when I went to buy spindle bearings for my riding mower--the parts clerk hands over BCA bearings,at 16 bucks a pop!--I needed 4 of them,and didn't expect them to cost more than 20 bucks total--when I told him I'd have to come back,he said "Oh,wait--we have them in "Auto Value" brand for 4 bucks apeice!"...so I was right,I got all 4 for the price of ONE in BCA brand!..but they wouldn't have told me about the cheap ones unless i asked or complained..
    Around here,Autozone USUALLY has the lowest price--but not all!--some are independently owned,and they set their own prices--you cant get the same parts for the same prices at the two stores only 5 miles apart!..many times the Autozones have the least experinced counter help too...you pay for the experience the guys at places like NAPA have,and sometimes its well worth it!..and most of the "real" parts stores either HAVE a "bargain" brand,or can get them--IF you ask!..:crazy: ..
  18. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I use partsamerica.com for most things and napa for the hard to find parts. Like leaf spring bolts or ball joint adjustment tool. napa caries some things that other stores do not.
    Partsamerica.com is great. The prices are much cheaper. I made a $315 order the other day that woud have cost me about $400 if I purchased them in the stores.
    Partsamerica is the online store for schucks/checker/kragen. You order online then go pickup your parts in one of their stores. You save lots of money and the best part is you don't have to deal with the idiot counter person. Just pick out what you know you need. great for ck5 folks since we know what parts we need even if they came from another make and model :)
    Napa is overpriced and sells the same brands repackaged as the cheap stores like pep girls...
  19. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    I only head to NAPA for the hard to find stuff...for any routine/common parts and supplies I just hit pep boys or autozone. These days, I find it much more efficient to look up specific part numbers online and just take them in though - to anywhere, and just skip the counter-guy-lookup.
    Between NAPA's and Summit's online catalogs, I can usually find just about any part I'm looking for. The chevy Truck Shop in Orange, CA is my fallback for any era-specific stuff.
  20. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    hopefully my chinese rotors won't warp... dang, my truck has communist parts :doah:
    Picked up the calipers they ordered at napa.. man, I'm really impressed with the quailty.. those things appear to be pretty well rebuilt, and come with bleeder screws and calper bolts... Probably gonna shoot some high heat enigne paint on the calipers so they won't rust...
    Gonna try to swing by and get some core calipers from a ck5er tomorrow, since I'll be in town. If I get to, then I guess I'll go back to Napa and order 2 more calipers... Would the ones from Advanced be the same thing? I could save myself about 10 bucks by getting calipers from advanced. I might swing by and see if they have any in stock I could look at...
