Homade gas tank
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JMZ, Apr 10, 2002.
  1. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    If you could build your own stainless gas tank for free.How many gallons would you make it? I am thinking about 35 - 40. What kind of fuel pump would you use for a carb motor? I have a sending unit from an 87 suburban. I`m thinking of using that sending unit with the electric pump and a pressure regulator.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would make it as big as would fit and not hang down any lower than the stock tank. I would use a mech. pump and not a electric...esp. not a fuel injection pump...you would burn it up.
