Home audio equipment
Discussion in 'The Lounge' started by alf4444, Jul 9, 2006.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I'd like to hear some opinions on home audio receivers. My current is a pioneer that I've never been too impressed with but its 8 years old now and on its last legs. I'm wanting to go with Harmon, kardon Denon, or Yamaha and looking to spend between $200-$400 any suggestions? Not looking for the "home theatre in a box" just a receiver for now and I'll look into new speakers in a few months:D
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I've always had greta luck with ANYTHING Pioneer, but I'm currently using a Kenwood "in-a-box" and it's great. Not audiophile by any means, but good.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I bought a HK 2 years ago, to replace an Onkyo. The Onkyo had higher rated power, but the HK sounds much cleaner, with the same speakers. 55 watts per channel will rattle almost any house, in surround mode, so keep that in mind. Look at THD specs and S/N ratios to find the cleanest sounding receiver. Good luck in the candy store.:D :D :D
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I have a JBL home theater system, but I'd deffently look into Harmon Kardon, Denon, Onkyo, Yamaha, or a JBL if I was in the market.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yamaha upper end is great. I would go for a mid line Denon though.
  6. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I say go with denon or marantz
  7. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    any models in specific? oh and I'd like to go with a silver model to match the HD TV:D
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I've got an original SAE two head and tuner set. Thing is as old as I am but sure does beat the hell out of all the new ones I've looked at.
  9. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,003
    826
    Pinckney, MI
    Denon is sweet... best thing I have heard in a long time.. so clear
  10. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Denon, Onkyo, and Yamaha would be my three major choices if I had the cash.
  11. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I've got a Yamaha receiver (model kvx-1400 I believe) that I bought about 2 years ago. THX certified, 110 watts rms per channel (7 channels), 6.1 decoding. Also has this trick feature where you set this microphone in the middle of the room and the receiver does a "self setup" that will check your speakers for the correct polarity, detect the speaker size and adjust the volume for each one, timber match everything so you can run different manufactures speakers and have them sound the same. Definatly worth the money but cost about $900 (one of the cheapest THX certified receivers at the time). Anything yamaha makes for home audio is sweet! I would even consider buying a used one.
  12. tuffdogstudio
    tuffdogstudio 1/2 ton status
    Nov 1, 2004
    239
    New Mexico
    Ahhh... the home audio equivalent to "What size tire will fit my rig" :wink1:
    For starters, every manufacturer of big brand "high end" equipment has good stuff and bad stuff, usually you get what you pay for, not always true, but usually.
    You need to ask yourself "what do I want my audio system to do?"
    If you want a home entertainment surround sound unit, I suggest you go that route and stay away from the HTIBs, build a system after doing alot of research online and buy second hand when you can.
    If you want a system to just relax and "Listen" to music, a home theater system will probably never (and I say this because we are all usually looking to not spent alot) satisfy your music needs (one caveat, it may satisfy you if you never listen to a high-end audio system.)
    Do you want a loud as hell party system? If so, thats completely different yet again.
    Personally, we have two systems, well more than that, but two main systems, a surround sound system connected to our TV that rarely plays music other than whats on a music tv station or on a DVD. And then we have a listening system just for music.
    A listening system can be very rewarding, but can also ruin you listening to music say in a car and at work and such, just never seems to be as rewarding after you've heard notes and instruments that you never knew were there before.
    So, after you decide what you want your home audio to be, you can proceede on building a system that will enrich your life... just be careful, its an addiction just like offroading and rig building (I actually have more $ in my home audio than I do in my offroad rig, by quite alot)
    Heres a great link to high end used audio gear and some reviews www.audiogon.com
  13. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Ok guys I decided on this denon AVR-886s RC Willey had it on close out to make way for the new models and I couldn't pass it up for the price and it was the last one. It was actually priced the same as the 786
    http://usa.denon.com/ProductDetails/2111.asp
    SO now on to speakers so I can get the full potential out of the 100w per channel Any suggestions? I'll be in the market as soon as I pay off the receiver!
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    I just bought a low end Pioneer that has 7.1 capabilities... I liek it so far.. It's a VSX-516x. I didn't spend much because I didn't need anything fancy...
  15. readymix
    May 30, 2004
    6,706
    26
    You will love the Denon.
    For speakers, I like my BA VR2's.
    Mine are a few years old but they out hit, and out sound the Bose system my neighbor had.
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Year and years ago Bose was the speakers too have, but I haven't been impressed with them in quite a long time. I still see people raving about Bose, but these same people live a sheltered life and are clueless about high end audio.
