Home built rear disk brake Q's
Discussion in 'The Garage' started by Skyetone, Apr 20, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    Home built rear disk brake Q\'s
    I got this truck...It has a 14bolt FF. It has rear disk brakes that are homegrown... I have to surrender the disks so I get a title (don't ask) I want to build them again. I have heard to get a front disk and caliper from a 44. And some bracket that holds it all in? Are the brake lines and portioning valves all the same? Can someone direct me to what it takes?
    This is a link to the disks as they are now..
    http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&albumID=36069497&photoID=36069530&security=JEUAyp
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Home built rear disk brake Q\'s
    You need:
    3/4-ton 4x4 front rotors (10B & D44 are the same)
    1/2-ton front calipers (10B & D44 have different banjo bolt size)
    1/2-ton front flex lines (10B or D44 to match your calipers or TSM)
    Brackets (Misfit and DEBERBINATOR(sp?) sell them...check the for sale section)
    This will set you up w/ disc brakes w/ no e-brake. If you want a e-brake you need either late 70's caddy calipers or a t-case e-brake from High Angle Driveline. I would not recomend line locks but some people still use them.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    45acp also makes and sells them. /forums/images/icons/wink.gif
  4. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    the axle is a FF14bolt 8lug. wich calipers do I need? Are the misfit and deberbinator companies? I'll look at the FS board but want to make life easy...
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Misfit and DERBINATOR as well as 45acp are all members on this site. They all make 14 bolt disc brackets.
    Calipers are 1/2 ton fronts...Rotors are 3/4 ton fronts.
    Rene
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Calipers are both 1/2 and 3/4 ton pieces. They are the same thing.
    But be aware that D44 calipers and 10 bolt calipers both use different size banjo bolts that hold the brake line to the caliper.
    The D44 uses a larger bolt than the 10 bolt.
  7. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    I guess I'll search FS then eh? Thanx....
