home depot welder
Discussion in 'The Tool Shed' started by surpip, Mar 20, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    this one:http://www.homedepot.com/prel80/HDU...earchResults.jsp&MID=9876&N=2984+3966&pos=n24
    or this one:http://www.homedepot.com/prel80/HDU...earchResults.jsp&MID=9876&N=2984+3966&pos=n24
    i want a cheap one now, and i will save for a nicer one later
    and keep this one for a portable unit, and dooing body repairs and stuff
    what do you think?
    there is one ther now9the cheaper one) that has a wicked dent, and i could probally get it marked down.
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    which brand and model. Your link just takes you to the general HD site.
  3. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Being that your links are broken, im not sure which model you are looking at. But, i have the 135 from Home Depot that i got for dirt cheap, and it works fairly well. Its not infinately adjustable voltage like the better Lincoln 135, but it does the trick. I bought mine for the same reasons, it was cheap and it will be nice later on to have a portable unit that i can use anywhere theres a 110v outlet. Im plenty happy with it.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    they have the 100HD there
    and a 375 or somehting like that, it can use gas and has casters on the bottom
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale.. get the 135sp.. you wont be happy with the 100hd.. it isnt strong at all,, we weld with the 135 sp all day at school and they are what ICAR now specs... for a first welder you will buy it and then like it because you can actually fab some stuff up to 3/8s if you get good... and not watch it burn up or not do what you want... youll throw away the 100 very quickly...
    EBAY.. netwelder or one of those guys... not HOME DESPOT.. they are full bore retail... I get my best price of the Inet then with it march down to Airgas and they have always matched it .... usually beating it
    I saved about two grand off retail doing this on my 350mp/python
    black rifle boyz have good taste and dont buy JUNK
  6. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummmm
    hobart is pretty nice huh?
    always hear about miller and lincon
    not much about hobart
  8. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    best deal you'll find on a 220 unit is the Hobart Handler 175.. It'd be my choice...
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hobart is owned by Miller and many parts interchange with comparable Miller models. But there are differences. Miller has all metal drive mechanism, Hobart is mostly plastic, but the Miller drive will fit a Hobart, that kind of thing. But older Hobarts were totally different than Miller.
    The Hobarts all come equiped for gas too.
    I would say that if you have a real interest in welding, and your sure it's not just a passing "thing", then get a Hobart Handler 145 at a bare minimum, you'll be much happier spending another $100 or so to get the 175 (or whatever they call it now) with 220V. I expect that for most automotive/4x4 work you'll be much happier in the long run with the HH175...
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well its needs to do dubble duty, small stuff fro rebuilding the mini sheetmetal
    and big stuff for the truck
    can i really do both well with a 220?
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well alright
    i guess i am sold
    wich model am i looking for again
    and with the plastic gears in the hobart, will it hold together for a while?
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    HH175 is the small 220V suitcase welder, I have the equivalent Miller MM175. For a hoby welder, or pretty much anyone who takes care of the machine, it will be fine. Main thing is to not try to drag the machine around by the gun like some knuckle draggers I've seen in some shops. Can't quite get where you want with the gun?? Just haul up on it and drag the machine closer. Next thing you know, the break the clip to the drive mechanism and swear they didn't do anything. That's the environment the Millers were built tougher to have at least some chance (or that is the sales propiganda anyway, not a good idea to test it).
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    790 bucks for that welder
    little much
  15. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    I've seen it for consistently under $600..
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    HH175? If so, yeah, shop around. I got my MM175 (on sale) for less than that if you don't count the gas bottle.
  17. dwoods
    dwoods 1/2 ton status Premium Member
    Jan 26, 2005
    303
    DuBois PA
    I think I seen it for under 600 at tractor supply.
  18. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya i was on the hobart website, they updated the model to the 180 and it was more
    i found a 175 on ebay for alot less
  19. ghostrider32
    ghostrider32 1/2 ton status
    Apr 17, 2005
    117
    HOLDENVILLE.OKLA
    GO CHECK OUT A FEW PAWN SHOPS I GOT MY HOBART 175 FOR $300.ALL IT LACKED WAS THE HOSE FROM THE FLOW METER TO THE WELDER. AND I BET IT HAS NOT HAD 18 POUNDS OF WIRE THROUGH IT. GOOD LUCK
  20. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Bought a Lincoln 175 PRO, NIB for $500 shipped. There are some good deals out there if you look around.
