Home-Done Bedliner On Aluminum?
Discussion in 'The Garage' started by Confedneck79K30, Feb 15, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    i want to get some of that duplicolor spray on or herc. roll on stuff to put on the steps of my freightliner... but it has aluminum diamond plate, will it work well enough? i dont see why not, but i figgered id ask...
  2. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    stay away from the duplicolor spray its never stayed on anything I have sprayed before, might try sanding the aluminum with some 80 grit to make the herc. stick
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    i second the sanding, whatever rough sandpaper u can get. Then clean it really well, and it should stick for a while.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if it was me, I'd sand the bejebers out of it and then coat it with aluminum-specific primer... then lightly sand... and then herculine it.
    j
  5. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    X2 on what Jekbrown said. I work with sheet metal on aircraft and the key to a good scuff on aluminum is to scuff past the alclad coating ( a thin layer of pure aluminum on the outside of aluminum for corrosion protection). Basically, you know you have a good scuff on aluminum when it is no longer shiny. Your metal should be a dull not shiny. I usually use a 150 -180 grit but for herculiner I would go down to around 100 grit. I would think that any "clean metal" primer would work. After a good solvent wipe down.
