home-fab shackle flip
Discussion in 'The Garage' started by big blazin sc, Nov 10, 2004.
  1. big blazin sc
    big blazin sc Registered Member
    Oct 14, 2004
    24
    Spartanburg, SC
    I was wanting to get a set of front 2wd leaf spring hangers and make a shackle flip. I was wondering if anyone had any info or pics on getting the existing shackle hangers off and the placement of the new ones. thanx
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I used the front hangers of a 1980 Chev shortbox 4x4, these are the "long" style hagners, which work with a shackle flip.
    I swapped in a set of 63's, so my locations are going too be totally differnt than waht you would need. I'll try to round up a digi cam when I get the change.
    A suggesgion when drilling new holes is to measure from, or even use an existing hole in the frame, to mak sure everything is square.
    To get the existing hangers off you'll need to grind or torch the heads off the rivets, and drive them through the frame with a BFH and a punch.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I forget who posted it , but there are members here with pics . If you can't find it , I am sure they will post up when they see this /forums/images/graemlins/thumb.gif
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think grvdigr (sp?) had done this. Why not just cut a hole in the stock hanger, brace it and flip the shackle? Thats what im going to do.
  5. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Well, what I did was use the front spring hangers from a 1 ton and used the top back rivet hole to line up on the top back rivet hole of the existing hanger. Worked just about perfect, my shackle is almost perfectly vertical when sitting level. I did have to space mine out with a piece of 3/4 inch bar make it line up right though, the stock piece sticks out a little further than the front spring hanger.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I was thinking of doing the same, anybody got anything bad to say about that approach?
