Home fix up question
Discussion in 'The Tool Shed' started by 77crewcab, Jul 17, 2006.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Need some advise on how to mount something to brick. I have a street number plaque that I want to mount to the front of my house. It is a wood plaque and mounting to a brick house. But I don't know what I need or any precautions that need to be taken. Any advise is appreciated.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    masonary drill bit and some anchors to screw into,just go to homo depot they can hook you up, or any hardware store...
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks I was thinking it was much more involved. One of those time when I try to overthink things.
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Try these anchors, they look good when installed, and are semi permanent, you CAN get them out if you really try. They dont rust and give a nice 'rivit' look on bricks.
    http://www.powers.com/product_05548.html
  5. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Personally I would drill the motar and not the brick itself. It would be much easier to repair if you ever remove the plaque.
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Liquid nails or a similar construction adhesive will work well. If you are worried about what it would look like when you take it down, just plan to replace it with another similar sized or larger plaque.
  7. K5Kell
    K5Kell Guest
    Personally I would not use a rowel(spelling) due to the fact that it could possibly cause a brick to split/crack. Also they are very hard to get out especially in this situation were you could easily damage the bricks during removal.
    -Kell-
  8. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    How 'bout these then?
    I've never had a problem with the drive pins in any masonry, though.
  9. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    I second Liquid nail , or the New Loctite Adhesive both work very well I've used it to Wrap steel beams with sheetrock works very well
