Home Made Lift
Discussion in 'The Garage' started by google, Jun 3, 2005.
  1. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    My truck has a 4 in body lift on it. The rubber and what not used to lift it is squishing and cracking and looking like crud. What would you guys on a budget use to fix this problem on a budget? I have heard hocky pucks, wood, steel pvc pipe from home depot etc... any openions would be appreciated.
    One other question.... what kind of lift is needed for rock crawling meanies that have all that travle in their suspention? You know, the guys pulling up on the ramp with one tire 4 feet up the ramp and tire in the wheel well and all three other tires on the ground?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    This has to be one of the best post's ever!!! :D
  3. google
    May 19, 2005
    805
    Arizona
    Are you making fun of my redneckedness or was that a compliment? By the way, i'm getting the personalized GITRDUN licensplate.... just kidding
  4. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Save your money and do it right, with an actual kit. 4inches for a body lift is crazy anyway. If you just ghettofab you truck, you'll never truly have the truck you want. Trust me, I know...
  5. google
    May 19, 2005
    805
    Arizona
    It was done with a kit, but it only needs those parts replaced. Can you go out and buy JUST THOSE PARTS? Where would I look? Wouldn't it be just as functional if not more so with something harder lifting it than rubber crap?
  6. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    from what i know you cant buy a 4in bodylift, the most is 3. if i were you i would order a new kit and replace what you have with that. they run about 100 bux
  7. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I wouldn't go 4", but I have made one 3" (customer request) I just got a length of 3"x3"x3/16" square tube and cut it into 4" sections. Drill the holes and get bolts (U have the bolts allready) and bolt it in. With the truck having the body lift on it now all the other work is done for ya.
  8. google
    May 19, 2005
    805
    Arizona
    Was that solid core? Is that what you ment by drilling the holes? I'm new to all this, so i need laymens terms. Before this, I had a 2000 dodge ram and I never did a thing to it but buy 36in mud tires. It already had a lift enough for them.
  9. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    No, sorry bout that :) I used square tube (hollow center) 3" suare, and it had a 3/16" wall. If U lay it on it's side all your'e blocks will be exactly the same higth, then just drill 1/2" holes through the top and bottom in line and it will repplace the bad blocks U have now.
  10. google
    May 19, 2005
    805
    Arizona
    OH, I get it. Turn them on their side. Don't cut them 3 in long.
    Cut them to fit
    turn them on their side
    drill 1/2 hole
    replace existing crap
    that about cover it?
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    DO NOT BOOTY FAB YOUR TRUCK. if you wish to replace your current body lift, that's fine. spend a few dollars more, save yourself the hassle of making the body lift blocks, and most importantly, do it safely. personally, i'd ditch the body lift, and go with a high quality suspension lift. start with something simple, like a set of BDS or Tuff Country springs and a shackle flip. that should flex fine for most applications, and is actually a very common setup around CK5. if you wish more flex than that, you should look into 52" or 56" spring swaps for the front, and 56" or 63" springs for the rear. if that still doesnt get you enough, you're going to have to look into alternatives other than leaf sprung suspensions.
    what type of terrain do you normally deal with, or intend to deal with? and what type of drivetrain does your truck have in it now? wheels and tires? axles? gear ratios? trans and transfer case?
  12. google
    May 19, 2005
    805
    Arizona
    River rock and rocky desert. running a 350 with 3 speed turbo 350. 33 12.50 AT. 14 bolt. dunno about the gear ratios or how to find out. Dunno about the transfer case either or how to find out.
  13. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    The "rubber crap" you keep referring to are probably your body mount bushings. If they're in that bad of a shape then you should replace them. You can get the stock ones from the dealer or you can get urethane bushings from many aftermarket suppliers.
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    craw under your truch and look at the t case there should be a metel tag round 2" in diamiter rivited to the case look for the number on it. (ie. 208, 241, 205, ect.)
    if you want to find you ratio, it takes some more work, you must pull a diff cover drain the oil and look on the ring gear (big one) on the out side edge there will be a set of numbers, one it the number of teath in the ring (big gear) and the other the number of teath in the pinion (smaller) gear. devide them and it will give you your ratio.
    oh and take pics so we can see whay axle it really is:D
