Home made rear bumpers
Discussion in 'The Garage' started by BLZN4FN, Feb 28, 2007.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Looking for pics or some kinda of design of your home made rear bumpers that will fit a K5.
    I just cant bring myself to pay 350-450 for a rear bumper
  2. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    imagine anything.
    draw it.
    build it.
    i like simple stuff built out of square or rectangle tube, but some guys like to go all fancy-fanse with round tube. that's too much work for me.
    do what you want.
  3. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Hey Bo,
    there was a kid on the board that mocked his bumpers up using cardboard first then laid out the pattern and built from there. I thought it was a great idea, might try that.
  5. sganje
    sganje Registered Member
    Jul 31, 2005
    44
    Denver, CO
    Hey, here is a picture of the bumper that I am working on right now. Hope this works(the picture). I still have to figure out a latch system of some sort. I hope the grade 8 bolt will hold too.
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Is the grade 8 bolt your hinge? :eek1: Might need to rethink that.....
    Not sure that will hold up, what size tire you planning to run?
  7. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    I really like that style of tire rack. Would like to build something similar for my rig. Needs to accomodate a 37 inch tall spare though...
  8. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    That grade 8 won't hold. You need something meant to be a hinge and heavy duty.
  9. sganje
    Jul 31, 2005
    44
    Denver, CO
    This is a fellow CK5er that is on this website, this is his write up.
    The rear is 2x4 and 2x2 3/16 with 10 guage sheet metal. The tire carrier is 2x4 3/16 held on with a 1" x 10" grade 8. The bolt has 2 contact points and passes through 4 sections of the 3/16. There is a grade 8 nut welded in near the bottom. I also ran a seam down the path so that the bolt threads all the way down and used flanged bronze bushings to keep things smooth. The other side is a 9/16 grade 8 and another nut welded in.
    I was just going off of this, so I don't know what to do if you guys say it won't work.:doah:
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That's mine. There are 2 contact points for the bolt and it works great. I have a 37 inch spare and 10 gallons of gas back there 24/7.
  11. Snowman1000
    Snowman1000 1/2 ton status
    Jan 28, 2007
    518
    Freeland Michigan
    Big 3/8 inch think diamond plate all arc welded together and ground smooth on the edges modeled after a regular chevy bumper with the big notch out in the center for the licence plate and it has a big pintle hitch used to pull dozers.
  12. cbbr
    Jul 17, 2004
    14,681
    Here is the full writeup with the pics.
