home made shackle filp??
Discussion in 'The Garage' started by K-5kid, Apr 22, 2005.
  1. K-5kid
    K-5kid Registered Member
    Mar 24, 2005
    35
    el paso tx
    i am thinking about doing a shackle flip on my 73. does anyone have any tips on how to do it. I am doing it to get rid of the 4inch blocks and i wont be doing any towing. and pros or cons on this would be great
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    do a search... there are at least 10 different threads on a homemade shackle flip...
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
  4. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Do a search for all posts by "Bboy" on here, he made a home-brew shackle flip and it came out really nice.
  5. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i the front spring hanger on the rear springs as a flip
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Need a flash for that pic. The background is too dark to see the frame and shackle.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why does everyone use the front hangers? Because you could move them forward or backward when you put them on? I think it would be easier to just cut a hole in you stock hanger and brace it up, thats how im going to do it anyway.
  8. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i tried the cut thru setup. flipped it back after two days. horrible shackle angle ,rode like a dump truck. tried removing leaves, didnt help.
    its worth it to get a ORD flip or use a front bracket. tho i think the ORD flip should have a better angle. i guess its ok for an all around rig, works good for towing and such. i want to move mine forward a bit and maybe run a longer shackle.
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i cut my rear hanger and stuffed the shackle through it.... works fine. i may get some longer shackles. but its not needed
  10. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i did homemade flip but used 56'' and longer shackles 8.25 hole to hole . great angle.7''lift.
  11. jrpeebles
    jrpeebles Registered Member
    Jan 19, 2005
    40
    North Hollywood Ca.
    For real heavy offroad use, how much strength is cutting all that material out going to leave, even if you reinforce it? How many have broken shackles and shackle hangers?
  12. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I did the "cut a hole" trick and don't like it. I have 5.5" lift rear springs and there isn't anywhere close to enough room inside the shackle hole for the shackle to move when the spring compresses. I will use some front hangers from a 2 wheel drive that I scapped today with longer shackles.
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you have the cut a hole method already just continue it. Reinforce the shackle mount with some angle iron or C channel and gusset it all up. Then cut the rest of the bottom of the shackle out.
    That is how az-k5 did his shackle flip. It works great sofar and he beats the hell out of it. He has since swapped to 56's out back and that is all good too.
    Collapsing a shackle isn't that hard to do if you beat on your truck hard. Making some beefy replacement shackles isn't terribly hard and they will last way longer then a stock shackle.
    Harley
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, thats how I was going to do it. Make it nice and reinforced, and just make the hole as big as it needed to be.
  15. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I did the cut through method three years ago, works fine, no reinforcement. I was thinking of reinforcing it, just haven't got around to it. With stock springs there is plenty of room for shackle movement. Longer shackles, that would make a bad pinion angle even worse, would really need to move the spring perches at that point. As it is now my pinion angle is about perfect for a c/v shaft...too bad I don't have one :crazy:
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  16. K-5kid
    Mar 24, 2005
    35
    el paso tx
    so would it change my pinion angle enought to need a new drive line or can i keep the one i have
  17. jrpeebles
    Jan 19, 2005
    40
    North Hollywood Ca.
    You should be able to use the one you have but degree shims or cutting and rewelding your pads to the correct angle may be necessary. You may also have to lengthen the driveshaft.
  18. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    487
    Grand Rapids area
    If it rode like a dump truck, your shackle was probably hitting the bracket. Was this with stock springs or aftermarket? I did it with stock rear springs and the shackle angle is really good. The ride is also good.
  19. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Like already said, need to shim it at the very least, and probably will need a longer driveline, mine was 2" longer than stock and was about right(also have zero rates). I had 1.5 degree shims in mine, wasn't enough. I need to reshim it at some point, took mine out when I swapped springs. I think I will get steel shims and bolt them into the spring pack the next time around.
