Home made shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Aug 8, 2002.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    I'm seriously looking at this. http://www.coloradok5.com/shackleflip.shtml
    Now I have a question about it. Why are the rivets removed and replaced with bolts and nuts. I don't see any change in position of the hanger.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    bad link/forums/images/icons/crazy.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    they most likly took it off to cut the hole in the bottom of the hanger
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Next is the fun part, you need to remove the rivets that hold the spring hanger. These can be ground off, torched off, drilled out, or cut off with a chisel (have fun). You do not HAVE to cut the shackles off the vehicle. I did so because the torch I have access to was not where the vehicle was located, they don't allow welding with in 50' of a fuel source, and before I actually decided to use the stock perches, I had already purchased some stock 2wd. front rear-spring hangers. They can be used in the rear and work very well, I just didn't want to try and "guess" what would make the truck ride even. I decided to use the stock ones because the holes were already available.
    he removed so he could cut the hole.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    isnt that what i said????????? lol /forums/images/icons/smile.gif
  6. Sammy
    Dec 8, 2000
    250
    Hmm, darn. How stupid of me. I guess I should take more time to read stuff like that. I stand correted.
    Thanks. /forums/images/icons/blush.gif
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    it took me forever to retype that part,lol!!!/forums/images/icons/laugh.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem thats what we are here for is to help /forums/images/icons/smile.gif
  9. Sammy
    Dec 8, 2000
    250
    And helping you guys did over the years in a big way. Right now I am reconstructing the blazer almost complete. 3 years back I would not have the guts for it.
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    awesome glad to see your building it up /forums/images/icons/smile.gif
  11. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I did not remove the hangars to cut the holes in mine. I took three heavy beach towels, soaked them with water, and wrapped them around the gas tank. Then I had my wife stand by w/ a fire extinguisher and watch to make sure I didn't start a fire. Worked fine for me. After I made the rough cut, I finished it off with a die grinder.
    John
  12. Sammy
    Dec 8, 2000
    250
    as my tank is totally out, I think I will be fine. Thanks for the help all.
