Home made shackle flips
Discussion in 'The Garage' started by k5 krawler 50, Jun 6, 2004.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Does any one have pictures of a home made shackle flip using the stock hanger that gives you about 4-5 inch lift? Thanks.
    Cory.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You may not have seen it , but it was done here awhile back. Found on here /forums/images/graemlins/k5.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    You can also check my sebsite in my sig. I have a writeup with some pics of the one I did. Just don't weld yours on like I did. Bolt it, you will be glad you did.
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    just cut a hole and flip the shackle through it... there isnt much tech about it /forums/images/graemlins/weld.gif
    i never bothered to put the reinforcements back on either... that was 1 year and 12 wheeling trips ago.
    but i also dont haul any loads
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    How much lift did that give you with just cutting the hole like that? That was pretty much what i was thinkin about doing, since money is tite, and just wondering how much that would give in hight? Thanks.
    Cory.
  6. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    it'll give you lift equal to the length of the shackle
    (as long as you reuse the same length shackle)
  7. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    is there any other modifications that need to be done to accomadate the shackel flip?(shocks, steering componets, ect..?) does anyone have any more pictures?
    thanks /forums/images/graemlins/k5.gif
  8. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    i jus looked at my truck and realized that this would only work in the rear? what do you do about the front?
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You get new springs as the front already has shackle hanging from factory, stronger ORD shackles would be a good idea also ( I'm getting some soon ). Don't forget a steering brace since you plan on lift/bigger tires.
  10. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I saw an echobit flip in another post, i kind of like the idea but people said it went tits up, so i think i am gonna fab up my own flip. I have a question for the people with the echobit flip, if you could, can you measure the hight of the bracket, and how much lift did that give you? Thanks again.
    Cory.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If someone doesn't beat me to it , I will measure mine tommorrow ( Truck in garage and I'm ready for bed ). There are pics in my signature links though. I lucked out and found my flip kit in town from another member . /forums/images/graemlins/k5.gif
  12. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    I'd be interested in seeing the measurments for the Echobit flip kit also.
  13. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Is there anything you have to do to the front shackle on the rear spring? Or does it just raise your pinion angle up alot?
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    It raises your pinion angle up a lot. You'll need a shim or else you'll probably be set up for a C/V rear driveshaft.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I plan to get a cv shaft anyway,my current one is screwed up so I guess ill get rid of the blocks and get the cs shaft at the same time.
    /forums/images/graemlins/thumb.gif
  16. sr175
    sr175 Registered Member
    Mar 31, 2004
    76
    Tracy, CA
    That pic of the flip is about what mine is but the cut was from the back of the truck to just forward of the shackle. It lifted 4" but changed the pinion angle. I dropped the Tcase 1" and helped a lot. I may also need to do something with the rear axle to make it a little better. When speeding up it will vibrate a little at various speeds. I just did a pismo trip with it loaded to the hilt and pulling trailer. No problems with strength or the way it handled. Handled all the offroad abuse just fine.
  17. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Hey i was checking out your pictures of that lift in the rear, and was wondering if i will be able to run the driveshaft i have now, lengthened or not dont know?, or will i have to just buy a cv one at the same time? Also where did you get your drive shaft and how much did it cost you? Thanks.
    Cory.
  18. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Forgot to ask.. what kind of transfer case are you using and did you get some of the measurements too? Thanks.
    Cory.
  19. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
  20. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Didn't get home until now, was at Kenny Chesney concert. Anyway , I looked at my flip bracket and its a hair over 4 " wide on top and 3 1/2 " wide on bottom. The bolts on top and bottom are 3 1/2 " apart and bottom bolt 1 1/2 " foward. The bolt where the spring attaches actually ends up in roughly same spot it was( look at the bolts in my pic ) and the open end of shackle faces rearward. So it appears to lift higher than through the bottom stock flip , which explains why I got more than 4 inches of lift .These look simple to cut and weld up , wish I had a welder, would copy it for friends since Echobit went bye bye .
    BTW , there is a gabriel shock now in that spot !!
