Home made shackle flips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Nov 3, 2001.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Anybody done their own? I mean by cutting the bottom part of the rear hanger so you can just flip the shackle over and thru the hole. The time is near that I'm going to finally lift the Blazer I have. It's going up to 4" and getting the "new" 35" tires I got today on a smoking deal. Read my thread on the "tires/wheels for sale/wanted" forum.
    So, any ideas on the home made flip?
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Yup. Can't say for sure, but I may have flipped the shacles around for clearance ( I think I did). Been that way for ~5 years, no probs.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    24
    El Paso, TEXAS
    My friend did it, i don't think he has had any probs, but I'll ask, I can take some pics too if you like.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    my buddy jason AKA, Blue Beast. he took the front spring hanger on the rear springs off a parts truck and took off his rear spring hanger swaped them and there was 4 inches . I think you can buy the hangers for around $20 bucks or so.
    colin
    Save the whales Harpoon a fat chick.
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I have a set of front hangers for the rear springs that I'll sell for $25.00. That's what I gave for them. They are from a blazer/jimmy frame. PM me if you want them.
    thebigdaddyof2
  6. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    I think the Front hangers from the rear springs look really good. The blazer on here that did it, the guy did a really nice job on it.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Thats how I lifted the rear of mine. I used a plasma cutter, but I ve heard of people using a grinder. I was easy and works great. Just make sure you cut enough so the shackle doesnt hit the hanger.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  8. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Do you have any pictures?
    I'm thinking of doing the samething and would like to see what it will look like.
    Ric
    <font color=red>Wheel hard or go home.</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>MY K5</a>
  9. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
  10. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i did mine w/a plasma cutter and cut the hole rather large then i took a 1/4x3x6in piece of steel, had it press-bent at a 35degree angle, i drilled a hole so the shackle bolt could go through it and then gusseted it to the outside of the shackle and up to the very top of where the shackle rivots to the frame. it cost me a total of $10 and about 4 hrs. and i gurantee its way stronger than ORD's and lets it flex every bit as well. oh-ya i also used shackles off a 92 chevy 3/4ton ( a little longer ). you have to use them backwards, and you will most likely have to reverse shim the rear end slightly if your not running a c.v. shaft. i got about 5-5 1/2in. of lift, hope this helps.
  11. fender
    fender Registered Member
    Aug 18, 2001
    92
    port moody b.c.
    <a target="_blank" href=http://wsphotofews.excite.com/038/qI/h9/IE/h567283.jpg>http://wsphotofews.excite.com/038/qI/h9/IE/h567283.jpg</a>
    I'm not sure who's that is, but he's a ck5 member, and I belive is from oregon.
    -fender-
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thanks to everybody who replied!! [​IMG]
    While I may be leaning towards the way the pic showed on what Fender showed us, this seems to be the cheapest and easiest to go. I cannot find any extra forward hangers to install. I want a cheap and quick flip, so may just plasma the holes under the stock bracket and call it done. Hope everything goes smooth when the time gets here to do it. [​IMG] [​IMG]
    If anybody else has more pics, go ahead and get them up so we can see more ideas. [​IMG]
  13. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hey man, that's my picture!!! I have a few more on my webpage. It's all pretty easy to do. I used a grinder and a sawzall. If you have any q's, feel free to pic away.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  14. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i cannot see how the shackle has enough travel in that pic.
    seems to have 1/2" before it bottoms on the hanger.
    as the spring flattens it elongates, the shackle moves towards the rear.
    looks like a bad mod to me.
  15. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Its all trial and error. The cut out was elongated after the picture was taken. Everything works like a charm now. I'm not sure what your definition of a "good" mod is. I realize it didn't come in a box from a big name brand and a bumper sticker but it's effective and it was free[​IMG]
    Jim
  16. michaelm
    Feb 2, 2001
    872
    a good mod to me is one that doesnt cause the springs to pound into the frame or brackets. if you say you have trimmed it back to where this wont occur, then that is a win.
    I havent tried it but it didnt look to me as if there was enough metal to trim to allow full range of motion.
    a recent magasine did a dodge and had a long list of trouble with not enough shackle travel.
  17. michaelm
    Feb 2, 2001
    872
    AND
    i am with you on the boxed parts, i dont have anything from the 'box parts' group on my truck other then some cheapo junk leaf springs, everything else is junkyard dawg on my ride
  18. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    What I did was 180 the shackle to face the other direction, then with a can of spraypaint in hand went out and tried to bind the suspension up the best I could, find where the paint had been scraped off the shackle, then cut some more and went out again. It's been a few months and so far so good.
    Jim
  19. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
  20. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    yeah but u have to run a trac bar, for street driving , i talked to guy that made that setup.
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)<P ID="edit"><FONT class="small">Edited by K10ANDYKHAMNIC on 11/04/01 03:47 PM.</FONT></P>
