Home made spring perch
Discussion in 'The Garage' started by balzackks84, Dec 8, 2002.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    I saw this on an FJ and was kinda freaked out about it. It looked like the spring perches were made out of 3" box tubing with the bottom cut out and notched to fit the axle tube. It looked to be about .190 wall but not sure. Was i over reacting or is it fine to do that?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Since an FJ is lighter in weight, the .190 wall thickness could survive supporting it.
    But many others have used 2.5 x 2.5 inch tubing to make perches for Blazers, trucks, etc. They use .25 wall thickness instead. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    What he said 1/4" wall 2.5"x2.5" tubing is what I use for my spring perches and I also box the ends.
    Depdog
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
  5. Depdog
    1,657
    Georgia
    Yep, thats my article on it.
    Depdog
  6. heavy4x4
    Aug 28, 2002
    3,270
    Yeah, I know...hope you don't mind me linking it.
    How are they holding up...any problems? Vibe noise/humm still gone after adding the shims?
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
  8. heavy4x4
    Aug 28, 2002
    3,270
    Those are pretty...look pretty stout too.
    Did you hand make them, or are they machined?
    Have you used the offset hole yet?
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    I cut them on a CNC machine, the off set hole is for 57" ford rear leaf springs and the center is for the chevy..
