Home made triple stick pics
Discussion in 'The Garage' started by MNorby, Apr 12, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Here is my progress on my triple stick. Basically waiting for 4 heims that I got off ebay (Score for $14 for 4 shipped) and to build some bling bling knobs of sorts. I may need to trim the bottom of the shift lever linkage off on the outmost one in case it come close to driveshaft but I don't think I'll be using that bottom hole anyways. Anybody see anything to improve them? So far I ahve all of $14 into it (heims) and about 4 hours or so.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    is it just me or is the shifter gonna be in the way of the d-shaft?
    but looks killer. did you build it yourself? what kind of busings did you use for the shifter pivot part? or any at all? what size heims are you using?
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    sure looks that way doesnt it...
    will the inside shifter clear everything?
  4. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    thats what I ment for having to cut the bottoms of the linkage off since I won't be needing the bottom hole on those outside ones. The bushings are 1/4" wall DOM with a 5/8 bolt through. Built it all myself. If I have to I can squeeze the shifter together tighter and get more clearance but if I cut those ends off will beabove the front output flange
  5. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    that looks badass, im still a newbie to all this though, i know that it allows you to control ur front/rear speeds, but what kinda situations do u use them in?
  6. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    you can independantly put the rear in high or low or the front in high or low or both in high or low plus a second high low range box. I plan on putting a micco lock on the rear brakes too and see if I can lock rear end and use front wheel drive and such too.
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    very nice fabrication...!!!
  8. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I trimmed extra off the shifter linkage mounts today, picked up some knobs and welded 1/2 bolts to the shifters to screw knobs onto and painted everything. Just waiting on heims now. How have ya'll installed your doublers, with the shifters on or off?
  9. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    I should remember. Pretty sure I weaseled mine in WITHOUT the shifters, then put the shifters BACK on (having testfit the setup off the truck). It was tight, but doable...
    Acha. Looking at the pix. I left the linkages attached to the '205, but took off the shifter rods and the stuff on the '203, basically.
    I did have to do some notching to get everything to fit.
    -- A
  10. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    alrighty, I will prob drop the shifters but leave ecerything alse there for the instal. thanks again for all the pics
  11. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I think that the lever to right has too much of the wrong leverage. It's going to want to twist side to side on it's axis and bind instead of pivot front to back.
  12. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    the front output shift rail on the 205 you talking about? The linkage will kick over about 1/4- 1/2" from side to side. I'll try to get a better pic
  13. dremu
    Feb 27, 2000
    15,967
    459
    I donno whether you meant right of the pic or right of the truck, but either way, this setup looks to be about the same as my ORD kit, which has no issues going where I want it to :confused:
    -- A
