Home made zero rate add-a-leaf?
Discussion in 'The Garage' started by jk3078, Feb 5, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    So what do you guys think about cutting down an old heavy duty overload and useing it like a zero rate add-a-leaf? I cant see any reason in my head why it wont work, and should be good for 3/4-1'' of lift at all for corners depending on the leaf used. Longer center pins will be needed but the're cheap. I know ORD's are cool with the 1.5 of set and all that but I'm a cheap bastard (broke!) and have lots of springs laying around. Thanks
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    there are quite a few guys that cut down overload for zero rates and it works fin for them
  3. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Ya I bet an idea like this is what got ORD's product going in the first place.
  4. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    I did it on the rear works great. I notice that the 1/2 are good for about 1/2 or 3/4 cant rember but i know the 3/4 springs are good for a full inch
  5. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    i did that for my front! just from a half ton spring though i only got like 3/4" lift if that.
  6. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I know a guy here in town who runs a truck shop and has lots of old springs laying around so I'm going to dig around and see if I can find somthing in the .75-1.25'' range. As far as that goes I wonder if regular 1x2 steel strap would work or if the steel is to soft? Any way .75-1'' lift would deff. help fit those new meats. 38.5x15's on 10'' wheels with 2.75'' bs is a bit tight with 5''s lift even with the fenders cut all the way to the floor boards!
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i used 1"x3"x12" 1018 cold roll.
    bought it for 12.58 from online metals.
    cut it in half, drilled two holes. shaved the end down.
    two center pin bolts were $4.
  8. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i cut my overloads, made them the same length as the spring pearch them benched a radius on the saw cut edges. worked great. you will get more axle wrap when you go that route though. should do some kind of anti wrap bar setup.
  9. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,001
    600
    Pueblo, CO
    The previous owner of my K5 did that in the rear. Except he used 4 1/2" thick cut down leafs. Had my pinion point down so far it would chew up a u-joint in 6 months of intermittant driving. At least they used one long spring bolt to tie it all together.
    I'd say 1 thick one is ok, but stacking a bunch is not a good idea.
