Home making a rear driveshaft...
Discussion in 'The Garage' started by PsychoticDeadGuy, Nov 20, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    could i go pull a front driveshaft for the CV part and put it on my rear driveshaft like this [​IMG] or will it not work? do i need to get it done professionally? are the front u-joints the s-44 style or are they 1310?
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Can you cut your own driveshaft and weld it back up?
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    i just wanted to add the CV part. I could cut and weld it if i needed to. i would then have to take it down to get it balanced. so, will just the CV part work with my 1350 u-joint driveshaft if i used conversion u-joints?
  4. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    If you use conversion u-joints, anything is possible. You will be adding length though, so the shaft will need to be shortened.
  5. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I may be wrong, but isn't the yoke part of the CV joint? I don't know if you can find a front slip yoke driveshaft.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    can i just get that piece off of a front driveshaft and use different u-joints?
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if u can weld it up i dont see why not....but im no pro
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    i wouldnt need to weld would i? i would just lengthen the wheelbase and use that one piece off of a front driveshaft right? anyone know for sure or have done it?
  9. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Lengthen the wheelbase with what, zerorates? I guess that would work.
  10. PsychoticDeadGuy
    Jan 8, 2005
    753
    yep, i have a pair of zerorates out back right now but there just for lift right now, if the driveshaft will work then i will move the zerorates.
  11. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    I don't know about doing it that way though. It looks like it would add roughly 3" in length to the shaft. You really want to run a 3" zero rate.
    I had to make a new shaft for the wife's Tahoe. What I did was cut an old shaft on the end that didn't have any balancing weights on it and welded it up to the new length. Not getting any vibes out of it and it's been 6 months.
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ment weld the cv from the front shaft to the rear shaft
  13. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i think i asked the same thing b4.. and outta all the mixed answers i got no.. who knows though..
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its not tha simple. you can't take the H yoke off a CV and put in using regular yokes and expect it to last. the yoke on the driveshaft and the slip yoke must have a centering ball and cup. if you don't have these, it will not split the angle between the two ujionts and will vibrate horibly.
    also you can't use a conversion ujoint on these. the other yoke must fit inside the H yoke. you can see somewhat in the pic. with a conversion joint, the driveshaft joint is larger and won't fit inside. and won't even let it rotate at an angle.
  15. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    I'm not sure i understand what you are doing.... shops have a ballancer to true drivershafts
  16. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Would the front driveshaft (which would be a smaller diameter than your rear shaft to begin with) have enough angle in the cv joint before it maxes out? You would have to do some modifying. I just got my shaft from HAD and that cv joint is huge and has tons of angle. I believe its a 32* cv. I'm not running it at that with a 4 inch lift but depending on how much angle you have I believe you should check out to see if that cv joint will be sufficient for your rear driveshaft angle.
  17. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    What if you took the slip yoke part from the rear drive shaft and cut it and turned it down and then made a adapter plate that you weld together to the slip-yoke. Then you could just bolt the front CV part together with the yoke, and then cut the "tube", adjust the lenght and weld it back together. Then you won't have the problem with the U-joints and balls and springs cause all that will be left untouched.
    What do you think? Because I also have a front drive shaft lying around... ;)
  18. PsychoticDeadGuy
    Jan 8, 2005
    753
    i am just trying to make my rear driveshaft a CV style so i have a little more angle. I am running a 5-6" lift and want to keep my u-joints alive for a while. all i would be using from the front driveshaft would be the CV part. that is it. and put that inbetween my slip yoke and my driveshaft to get a little more length and angle. my driveshaft is new and i dont want to scrap it and get an all new one made so i am throwing out ideas to help with the angle at my t-case. ive already lowered my t-case 1.5" and i want to tuck it up as much as i can without blowing up u-joints.
  19. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    The answer to your question is NO. Somebody gave you a long answer, but I don't think you got it.
    The drive shaft in the pic you show us has a slip yoke in it. That is part of the CV joint. The CV joint in that pic is more than what you have a cir. around.
