Home remendies....stuck lifter...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Jul 13, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    Remember now, I'm not in the states where I can trot on down to the local parts store and buy what I need...
    so...I have to improvise.
    Sticky lifter that's tapping. I recall someone used a little bit of ATF into the crankcase to help free it up as well as clean any grunge in the engine. Thoughts? Any other ideas I can use? Will ATF work? Or is it snake oil?
  2. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Problem is, when you "free up the grunge", it usually winds up settling/hanging in much worse places. Even in Asia I'll bet you can get a new lifter. Assuming you've checked to make sure the push rod, and rocker assembly are ok; and that you don't have a bad valve or broken spring, then there are no fixes that I know of for a collapsed lifter.
    On an loosely related side note, I once fixed a Pinto 2.3 with around 200k on the odo and severely worn cam followers (OHC) by dropping a washer down under the lifters to give enough pre-load to keep the followers from randomly falling out. It was still running 40k later when I *gave* away the car for the *3rd* time... It became a dirt tracker so I didn't get it back again... /forums/images/graemlins/crazy.gif
  4. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Be careful. Years ago someone told me that a little diesel fuel would do the same thing.
    Yup! Cleaned the engine real good. So good that a chunk of sludge came off something and blocked an oil passage in the crankshaft.
    Too bad. This was an old Studebaker 283 installed in a 68 Chevy truck.
    Advice is just that you must make the final decision.
    The cheap way usually ends up costing more.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    kersoene in the oil works but like noted sludge can go other places and too much kero well thats pretty thin oil.
  6. backcountry
    May 27, 2004
    916
    I use synthetic oil; don't have to worry about sludge!
    /forums/images/graemlins/peace.gif
