Homebrew Frame measurements?
Discussion in 'The Garage' started by the beast, Oct 4, 2006.
  1. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Is there a way to check your frame in the driveway to see if it's bent or not? I think my frame is twisted, but I'm not entirely sure. I'f it is, I'm not going to bother rebuilding this truck, I'll find another. By the way it's a 77 K10 shortbed.
  2. dyeager535
    26,980
    About the only "quick" way I can think of that would even be potentially accurate enough to do yourself is to raise the vehicle all the way off the ground so no susension components were being used to support the vehicle weight. Vehicle and floor would have to be perfectly parallel.
    Any measurements on the ground are pointless, springs, more weight one side to the other, and tires (along with a few other more uncommon things) can all have an affect on "height" when being used to check for frame straightness.
    Not to mention, there are very few "flat" parts of the frame...GM used various holes punched/cut/drilled through the frame to check for frame straightness.
  3. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
  4. the beast
    Oct 15, 2003
    535
    Providence, RI
    AWESOME Jeremy!! Exactly what I was looking for!! :waytogo:
