Homebrew shackle flips are fun
Discussion in 'Rocky Mountain Region' started by justhorsinaround, Dec 12, 2004.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I got to use a drill and a mini-grinder and even a cuttin torch!:grind: :weld: :grind:
    The funny thing is now that it's all done the vibration that I had round about 35 and then again round about 65 now is from about 1 to about 30 then it kind of dies away.
    Ah well such is life.
    It's all done and seems to work pretty well as it seems to ride smoother. Gonna have to find some place to see what the hind end does flexy wise. :D
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well . did you shim it back down yet ? That was what mine did , and I knew it wasn't good for the joints , hence my rear CV :k5: :k5:
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am running a home brew one too, with a 1" zero rate. No shimming from me. I did drop the 203 down an inch though. No real problems yet and I have had it that way for a few years now. I do change the t-case joint every 4-6K though.
  4. justhorsinaround
    Sep 16, 2003
    6,798
    Put the shim in and it comes a little closer to parallel so maybe I'm gonna have to figure out how to lower the t-case. Oh and I'm gonna have to clearance out the back of the holes a bit more on both sides cuz on account of the rubbin goin on. I figured I had more than enough clearance but it looks like I was wrong.
