homebrew zero rates
Discussion in 'The Garage' started by bigbadchev84, Dec 9, 2004.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i want to make my own so does anyone have the dimensions handy? i just want to use them as straight up lift blocks, my other question is, will a rear 3/4ton 2" block u-bolt work for the u-bolt right next to the diff on a 44? thanks
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Lift blocks on Front axle are a real bad idea. Lift it with springs or a shackle lift, preferably springs.
    EDIT: My mistake, I read 2 inch block u-bolt and thought that implied you wanted make a 2 inch zerorate for the front.
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    I thought zerorates were safe because they tie in with your leaf springs, i already have 8inch springs, just looking for extra room for my 39.5 boggers
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    How thick do you intend to make them? The ORD ones are only 1" thick. As for the other dims I would think the width of the spring pack and length of the pad on the axle.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    here is what happened when I told my buddy about Zero Rates. I told him, yeah to make some at home just cut down a nice thick overload spring. He figured 10 would be fine.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A rear ubolt from a truck with a 14bff will work for a front diff next to the pumpkin. A for blocks in the front that is a bad idea. A 1" zero rate is ok as long as it is part of the spring pack. Anything taller then 1" might be iffy though.
    Harley
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Found out about that when I kept trying to put the projects axle back in . That one u-bolt is spaced differently than the other 3 on 1/2 ton stuff , two different springplates up front too , left and right :k5: :k5:
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    What kind of abortion is that...?
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    check scary steering, I sent it in a while ago, theres stuff there about it. He has removed them.
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Are those front and rear shackles too?:yikes: :yikes: :screwy:
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    just front, they are factory ford mounts on his F150. Problem is he used an older style Dana 60 which has the narrower spring pads. If you check out scary steering you will see pictures of that work.
  12. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i was only wanting to go an inch, i got som 1"x4"x2.5" flat bar and the longer spring pack bolts, i just figured i could do it cheaper than i could buy them for.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    sounds like you are good to go then. I'd round the top edges in case the springs go negative it puts less stress on them at the corners of the zero rate. Otherwise I'd drill them holes and go. Make sure you have a new center pin and not just bolt them to the spring pack.
