HomeMade Driveshafts???
Discussion in 'The Garage' started by OffRoader93, Feb 10, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    I was wondering if a guy could just make his own driveshafts out of .25 wall round tube. Buy tube the same diameter as your stock driveshafts. Cut the stock driveshafts out where they are welded to the yoke and weld in the new tube. Making sure you weld them straight. I know for high speed this wouldn't be great cause of balancing issues, but for offroad wouldn't it work fine? I think they would be very heavy duty if done right. Any feedback or any info would be appreciate. Thanks a lot.
    Brenton
  2. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I just made my rear shaft last month when I did my auto to manual swap. I bought the tubing from a local shop and had them mill the ends down with a lathe toet them perfect. When I welded the ends on I made damn sure they were perfectly straight. I have been running the truck for a litte over a month with no problems.:D
  3. OffRoader93
    Nov 30, 2002
    262
    Hey thanks for the reply. I just think a guy could make some very tough driveshafts. On the farm we make all kinds of our own **** that gets abused alot and it never breaks. Thanks again.
    Brenton
  4. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    .25 wall is way strong. .125 would work. Never a worry with .25 though.
    A shaft in torque gets its strength from having a larger diameter more so than thick wall.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    You can also go thick wall square tubing.
  6. OffRoader93
    Nov 30, 2002
    262
    Would it be really hard to get square stock aligned with the yokes straigt? Thanks guys for all the input.
    Brenton
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Alot of guys have been running the square tube shafts for a couple reasons:
    Strong and Simple Slip shaft configuration.
    You can use 2 different size peices of square tubing that slide inside of eachother to transmit power. Works great for trail only use, but starts to vibrate alot over 20 mph.
  8. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    That's what I got in the front. So far so good. Cost me about $15 and I have about 10" of slip travel in it.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Keep in mind the friction between the two square tubes has caused transmission, transfer case, and adapter failure in the past.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    i.e. When lots of torque is transmitted through a square driveshaft there is tons of friction (and possibly even the smaller tube starts to turn inside the other) which prevents the shaft from slipping (getting longer or shorter) which is extremely hard on axles and t-cases.
