Homemade flip how much lift, any draw backs?
Discussion in 'The Garage' started by sled_dog, Feb 20, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Really trying to decide what to do with my rear suspension setup. How much lift does a homemade flip give you?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    It gives 4" of lift. I havent had any problems with my homemade flip.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Measure your shackle length. It should be 4". Consider that all you are doing is changing it from pointing up to pointing down. So, the difference between where it was and where it will be is 8". Consider that you are only lifting one side of the spring, so divide the 8" by 2 - you are raising it 4".
    -- Mike
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    good with this and a zero rate I should be somewhere around 6-6.5" of lift in the back. If I put in a 14 bolt ff will I need to lengthen or shorten my rear driveshaft with 6.5" of lift?
  5. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    no problems with mine either. i got 4" out of it.
  6. blueturd
    blueturd Registered Member
    Dec 3, 2002
    88
    Arvada, CO
    It's not too bad a project if youre willing to donate a little time and have the sh*t to do it. I screwed up my layout the first time and had to re-do the plate on the frame (I completely fabed new brackets, more beef!)
  7. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    got any pics and specs? what size plate did you use? any sketches I could peek at?
